Home > In Car Electronics (L322) > Reversing camera
Squirrel
United Kingdom 2009 Range Rover Autobiography 5.0 SC V8 Galway Green
Reversing camera
Hiya,
I've just got my 2006 MY s/c back from a service where it had the rear washer motor replaced. Since the car came back, the output from the reversing camera has had faint vertical lines running down it, and there's faint horizontal interference (which moves) as well.
Is this just a symptom of a loose connector somewhere that I can fix, or am I looking at a new cam sooner rather than later? Can I fit a 2010 cam in my car without major headaches?
Thanks for your help. Smile
Post #156170 8th Dec 2012 7:54pm
If you open your top tailgate and carefully pull off the top trim panel then you will see the connectors for the camera to the right of center (look for the hole)
Craig Thumbs Up
Post #156173 8th Dec 2012 8:19pm
Norway
Norway 2003 Range Rover Vogue Td6 Adriatic Blue
what type off cam can be easely equiped to this car. -03V td6
-72 Cadillac Coupe DeVille 7,7liter.
Post #156273 9th Dec 2012 2:53pm
