Home > Technical (L322) > White Coolant |
nikbarber Member Since: 16 Dec 2011 Location: Warwick Posts: 36 |
Not good news - sounds like oil in the coolant. 2005 FFRR Td6 Vogue
8th Dec 2012 8:54pm |
ollielloyd Member Since: 09 Oct 2012 Location: United Kingdom Posts: 120 |
So what does that mean?
8th Dec 2012 9:07pm |
What engine do you have? Milky coolant is a typical sign of head gasket failure, but I don't know L322's well enough to know whether or not this is a common problem. Is your oil level ok, and the oil a decent colour? 2005 FFRR Td6 Vogue
8th Dec 2012 9:17pm |
daveo Member Since: 21 Oct 2009 Location: london Posts: 2307 |
well in easy terms it means some where the oil in your enginre is getting in to the coolent, head gasket is a favourite one but it can be other things...my mate had it on his xr3 years ago,went in to fords and came out with a large bill..3 weeks later in conversation his wife mentioned that she topped up the oil in the wrong bottle. there was never a prob with the car... they will do a sniffer test on the coolent system and it will detect any engine gases, do you have any over heating issues. V8 facelift Range Rover Autobiography 22" wheels.
8th Dec 2012 9:26pm |
It's TD6.
8th Dec 2012 9:35pm |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7650 |
Is it milky under the oil filler cap ?
8th Dec 2012 9:43pm |
Cap looks fine.
8th Dec 2012 9:47pm |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3955 |
Have you tried pulling the dipstick out to check the colour of the engine oil?
8th Dec 2012 9:48pm |
Engine oil is black. |
8th Dec 2012 9:51pm |
There are two sources of "oil" that could contaminate the coolant, engine oil via the head gasket and transmission fluid via the transmission fluid cooler.
8th Dec 2012 10:03pm |
I'm not a massive expert here, not sure exactly why technically, I just know what you see as an end result, If you see what I mean. but if the head gasket is starting to / has gone, the oilway tends to connect with the waterway, so when the engine is running pressure getting where it shouldn't can do weird stuff.
8th Dec 2012 10:07pm |
Thanks for replies. I'll get Guy Salmon to look on Tuesday.
8th Dec 2012 11:24pm |
Transmission cooler will be significantly cheaper than head gasket, but neither will be cheap. Do you have a warranty? I would definitely recommend using a decent independent rather than a stealer. 2005 FFRR Td6 Vogue
8th Dec 2012 11:32pm |
Only had car 3 months and if you read post mentioned earlier in topic you will see I've been having another issue. In summary it had no oil in front diff and dealer has finally agreed to get new diff fitted at Guy Salmon on Tuesday. He's paying to get this fixed too! My worry is what else is wrong with this car! |
8th Dec 2012 11:36pm |
