Home > eBay & Bargain Spots > New style Silver and Rubber Heater Control Knobs
Flashman
England 2011 Range Rover Autobiography TDV8 Santorini Black
http://www.ebay.co.uk/itm/range-rover-l322...337e47376b
They have multiple sets, once this listing is bought they usually list another.
You will need to mod them to fit over the existing plain knobs. Tom
Current Drive
2011 4.4 TDV8 Autobiography - Santorini Black - Ivory Leather
Previous Drives
2004 Model Vogue Td6 (Touchscreen) - Java Black - Parchment Leather
1994 RR Classic 3.9 V8 Soft dash - Niagara Grey - Grey Leather
1972 Series III SWB Safari - Green (Hand Painted) - Black Plastic
Post #156258 9th Dec 2012 1:42pm
spanner
just done this
Post #156293 9th Dec 2012 4:29pm
How difficult is it to modify them?
More specifically, what's involved and how long?
Very tempted if it's a DIY numoty job. Si. <This is my name.
Post #156295 9th Dec 2012 4:49pm
Stryke
United Kingdom 2006 Range Rover Vogue SE Supercharged Java Black
+1 very interested.
Spanner, do yo have a photo of the outcome?
Post #156297 9th Dec 2012 5:13pm
Flashman
Cam Tech Craig did it too.
I have stripped out the inner plastic rings and am in the process of filing down the inner metal (waiting for the dremel to arrive). I think you might neet to cut through one of the holes ( to flex it more) in order to stretch it over the existing knob as it looks to be the same diameter (so a very tight fit).
The sat nav knobs are a little smaller. Tom
Current Drive
Previous Drives
Post #156538 10th Dec 2012 7:53pm
daveo
I am more in favour of taking the unit apart for a few reasons, you can fit the knobs properly and clean the circuit board that has the led's on, they can get quite dusty, you can clean the little fan in side that controls the climate control, you will be amazed how dirty these get, my one was totally seized
,i still need to do my height and stereo knobs but they look far better than the plain black ones, so if any one does there make sure to take some photos..
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  V8 facelift Range Rover Autobiography 22" wheels.
Post #156552 10th Dec 2012 8:40pm
Flashman
Awesome writeup Daveo, might give it a go before trying to fit them over the old ones. Tom
Current Drive
Previous Drives
Post #156605 10th Dec 2012 11:37pm
daveo
its the same seller i bought my ones from, if you ask he will have the complete knob with dial and centre switch, it was after i told him what i wanted them for that he started breaking the switches down. V8 facelift Range Rover Autobiography 22" wheels.
Post #156607 11th Dec 2012 12:10am
Flashman
Having tried to machine the new knobs it looks like they will only fit over the old ones if you machine the old ones to a smaller diameter. Thus exchanging the knobs is probably an easier option.
How easy is it to take the knobs off the old module Daveo? Tom
Current Drive
Previous Drives
Post #156766 11th Dec 2012 9:03pm
daveo
hi its not that bad of a job ,more fiddly then technical.you can give it a good clean while you are doing it...one thing to point out is that the chrome and rubber knobs on the front panel [dash] are different from the rear panel knobs and wont fit..i have a set from landrover parts and the would not fit, luck would have it i got my hands on 2 front ones and made a one perfect one, so you need to check to see if they are from the front or rear panel. V8 facelift Range Rover Autobiography 22" wheels.
Post #157100 13th Dec 2012 12:07am
