![]() | Home > Technical (L322) > Pre heat |
Standard though a lot will likely have the fob missing for it so just buy another and sync it up and jobs a good en |
Standard? Really? Not here AFAIK... |
Every TDV8 should have it from the factory, especially in any country where the temps can be quite low as the TDV8 needs the help to warm up |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35771 ![]() ![]() |
doesn't it need a remote receiver fitted for the 'remote fob' function to work... ... - .- -.
SteveyD Member Since: 11 Dec 2012 Location: Cheshire Posts: 352 ![]() ![]() ![]() |
I thought pre-heat was set from the head unit (the one i'm currently thinking about ripping out DOH!) |
'timed' preheat yes but if you have a remote receiver and a remote fob you can switch the fbh on whilst indoors.. ... - .- -.
JAYBOY Member Since: 17 Oct 2012 Location: South Wales Posts: 2204 ![]() ![]() ![]() |
My Vogue se has it with the remote. Wouldn't be without it.
keep the older version and peeps will think you're well endowed.. |
Stan
You have to differentiate: every diesel FFRR has a FBH. They are used as auxiliary heaters to augment the cabin heat on cold days because the diesel is so durned efficient that there is almost no waste heat ![]() You can not pre-heat with this tho. Unless you enable the 'Park heat' function. Which yes, now is a doddle to activate... ![]() But 'Park Heat' was an option - and not inexpensive given what LR actually 'added' to the vehicle... ![]() ![]() RRC 2Dr, RRC 4Dr, P38, and 2 L322s (wife thinks I'm nuts - prob right, too) |
Yes, that would be another disadvantage. Do you have timed heat in the menu? ![]() RRC 2Dr, RRC 4Dr, P38, and 2 L322s (wife thinks I'm nuts - prob right, too) |
mark_j Member Since: 11 Dec 2012 Location: somerset Posts: 78 ![]() ![]() |
Ok, i know that all diesels have the FBH, but the remote was an option, how do i tell if this is installed and they have just lost the remote, or if it does not; and never did have the receiver fitted? |
http://www.fullfatrr.com/forum/topic15276.html
