![]() | Home > Technical (L322) > FBH receiver location |
mafford Member Since: 29 Nov 2012 Location: United Kingdom Posts: 4 ![]() ![]() ![]() |
I did mine this morning, if you remove the three screws holding the fuse board in on the first picture and gently pull the board out to give you a little more room to play with you will then be able to move the white siemens box out and behind that you'll see two connectors coming up from behind the board that the siemens box fits against, the right hand connector is black and I think has four small wires coming out of it - this is the connector that you need to remove for 5 seconds before reconnecting it and pressing the off button on the remote to pair the remote to the receiver. Took me about five minutes all in and then a toastie warm car this evening |
Mine's a TD6 - it might be different on yours, should be the same box but maybe a different position the receiver is quite thin and not much wider than a fag packet |
its worth saying that not every td6/tdv8 has a remote receiver, timed/manual input yes but not a receiver.. ... - .- -.
simon1233 Member Since: 13 Jun 2011 Location: Leyland, sometimes Darmstadt Posts: 650 ![]() ![]() |
If you have a receiver it should be located on the rear side of the metal plate that holds the rear fusebox, directly behind the white siemens unit. on this picture you can see the power connector that you need to unplug (small multiplug right at the back with white/brown/red wires) next to the ariel connector (yellow plug) which runs up to the tv ariel on the drivers side of the car. I managed to do mine without having to remove the fusebox |
taskam Member Since: 01 Apr 2011 Location: Shandon Posts: 121 ![]() ![]() ![]() |
Thanks for your comments guys. I'll check at the weekend to see if I have the receiver installed. |
Took the fuse panel off again and found it where Mafford and Simon said. Easy when you know where it is
Enjoy! It's my favourite thing so far about the car especially in this weather |
