Home > Maintenance & Mods (L322) > Rear headlining drooping
JW911
The edge of the rear headlining on the right side next to the upper tailgate has started drooping. Has anyone got a suitable fix before I spend ££££ please? 2021 3.0 P400 Vogue
2012 4.4 TDV8 Westminster - gone!
2007 3.6 TDV8 Vogue - gone!
2003 4.4 V8 HSE (LPG) - gone!
2018 F-Pace 25t Portfolio
1974 LR Series III Lightweight FFR
2014 BMW 640i Gran Coupe
Post #156909 12th Dec 2012 1:06pm
Never heard of this problem on a FFRR. Maybe it has been causes by a previous owner/vendor steam cleaning
Post #156913 12th Dec 2012 1:11pm
JW911
Relatively simple fix actually. I took a closer look and found the D-pillar trim wasn't clipped on properly (not sure if it ever was as one of the plastic fixings was bent). I straightened the fixing, reattached the trim and it seems to have solved it. Thumbs Up 2021 3.0 P400 Vogue
Post #156924 12th Dec 2012 2:04pm
There are clips, fixed to the roof, that the headlining clips onto. Maybe one of these has come away. I know because the one in the centre has done this on mine (following install by previous owner of wiring for wireless headsets). Never got round to fixing it. .
Post #156925 12th Dec 2012 2:05pm
As above, the headlining next to the rear pillar is held in place by the rear pillar trim.
Post #156928 12th Dec 2012 2:15pm
dave699
England 2007 Range Rover Vogue SE TDV8 Stornoway Grey
Same as Joe90 for mine.
Dan (Duckworths) sorted me a new clip.
In the centre its two parts - a metal U shaped piece with teeth and a plastic T shaped piece which attaches to the headlining. It really is a two minute job. I removed the rubber tailgate seal first, then fit the new clip and pressed the headlining into place. The rubber tailgate seal then covers the edge of the headlining.
Had it, loved it!
2007 Vogue SE TDV8
Stornoway Grey / Ivory
Climatic Seats, RSE, AFS, Deployable steps, iPod kit.
Post #156929 12th Dec 2012 2:18pm
JW911
I may need a couple of those clips in that case. Do you have a part number please?
I'll send my Dad to Duckworth's as he's only ten miles from Market Rasen. Thumbs Up 2021 3.0 P400 Vogue
Post #156937 12th Dec 2012 3:04pm
dave699
I'm at work at the moment, but 99% sure I still have the invoice. I will try and find part number when I get in tonight. Thumbs Up
Had it, loved it!
2007 Vogue SE TDV8
Post #156946 12th Dec 2012 3:29pm
