![]() | Home > Technical (L322) > l322 height adjustment with BBS faultmate extreme |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35770 ![]() ![]() |
not many here have this diagnostic tool so you might not get a quick response, have you tried asking on the bbs forum? ... - .- -.
nkc Member Since: 25 Nov 2012 Location: Nigeria Posts: 15 ![]() ![]() ![]() |
thank you, will do so now.
this is from member Joe90's gallery and will give you some idea what the height measurements are..
thank you so much,
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6424 ![]() ![]() |
That's what the book says. I have a similar problem with LH front being @ 10mm lower than RH front. My diagnostic tools so far have been unable to adjust this. .
exactly my problem, thank you for ur response.
During normal operation +10mm is normal. If you have set the suspension to tight tolerance mode (only 2006>) it should go to +3mm. This is only for servicing such as for an alignment, tho. Leaving it in tight tolearnce mode will throw faults and waer the compressor very quickly.
thank you so much steve. 2012 Range Rover Autobiography - Faultmate MSV2 Extreme - IID Tool |
