![]() | Home > Technical (L322) > Strange vibration at speed |
This afternoon I got a strange vibration on the motorway home.
No just on the straight and angle of wheel seemed to make no difference when pulling onto the hard shoulder from lane 2 as I was just about to creep past a lorry |
TC? |
Don't even bloody jest John!!!
Lloyd Barnes Member Since: 21 Apr 2011 Location: Shrewsbury Posts: 181 ![]() ![]() ![]() |
Strange this thread should pop up... mine is doing something very similar. Very distinct thumping noise/feeling (in my case from rear) almost as if there is a large stone caught in the tyre treads. Does it for about 10 minutes then goes away only to reappear for 10 minutes or so every hour.
Well mine hasn't re-appeared im afraid Lloyd |
Well, in my case the culprit seems clear once the wheel was off. Sticking O/S/R caliper. Brake pads virtually gone (almost no wear on the other side).
RRVSE Member Since: 18 Apr 2009 Location: Bury Posts: 597 ![]() ![]() ![]() |
Same here , I was getting what I would describe as a juddering effect, noticeable around 50mph and if I accelerated quicky it was worse but if I did it slowly it was a bit better. If I used sport mode it wasn't as bad but still noticeable. I started thinking transfer box after reading some threads on here, but mine turned out to be that the n/s/r calliper had ceased (also noticeable by disc running at 286 degrees when I checked it!!) New calliper fitted and judder has gone. I also had o/s/r one replaced under warranty as lasted 10months and o/s/r outer pad was basically only the shoe left and had resulted in a heavily scored disc !!! Why they don't put sensors on all 4 'corners' I'll never know. Steve
I changed both rear calipers when one was sticking. The calipers were quite reasonably priced by the dealer (70 Euro each) with trade-in of the old calipers. There are a lot of internet based businesses and I bet Duckworth Dan can give you a good price and fast shipping. MY 2010 5.0 SC Galway green and sand interior!!
Gonna have to check them next weekend me thinks if i get a chance as im away this weekend |
Mine have just been delivered by Brakeparts, excellent service and price. Thats this afternoons job sorted. Hoping it will sort it as I was thinking the worst and fearing it was drivetrain related! |
Well, the new discs, pads and caliper are on.. and the noise is gone!! |
Proved the theorem last night gents, it appears the rear pass side calliper is sticking after the car is washed at low temps... Think I'll order a refurb kit from brakesint and strip it and see what's up or buy another calliper depending on the price of the kit..
Hunttheshunt Member Since: 02 Oct 2012 Location: Hants Posts: 92 ![]() ![]() ![]() |
I seem to have picked up something similar. Last week I noticed that the rear brake discs were badly worn with quite a lip, so had made a note to get new discs and pads.
