![]() | Home > Maintenance & Mods (L322) > Fitting Battery Brain, electrical question |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3983 ![]() ![]() ![]() |
Have you considered a battery drain back thro the alternator when the car is not being used? |
user58101 Member Since: 13 May 2012 Location: London Posts: 11 ![]() ![]() ![]() |
I haven't tested for a battery drain back to the alternator when the car is switched off.
Does this (battery Brain) only kick in after all the systems (e.g. DVD / Airbags) have shut down? .
The Battery Brain only kicks in if it finds that the battery voltage has dropped below 11.8V.
Battery drain back thro the alternator starts as soon as the alternator stops rotating. It will occur in addition to any other current drains that may be present irrespective of the "sleep" condition of the car. |
roger 47 Member Since: 24 Aug 2012 Location: Exmoor Somerset Posts: 80 ![]() ![]() ![]() |
Correct me if I'm wrong.
Roger 47 - I think you're correct. However, this is unlikely to happen after driving the car.
I agree abrownson if you have a good battery and an alternator delivering the correct output.
If you have 11.8V on shutting down the ignition you have serious problems.
Go on.............. . Experience is the only genuine knowledge, but as time passes, I have forgotten more than I can remember ![]() Volvo V70 P2 2006 2.4 Petrol 170bhp Estate SE MG Midget Mk1 1962 Previous: L322 Range Rover TDV8 3.6 2008; L322 Range Rover TD6 3.0 2002; P38A Range Rover V8 1999 |
To continue... |
Thanks NDFI
Can't see how this would make a circuit? If you mean item 6 on image below?
No not the battery side of the jump post, the cable on other side of the panel that drops down to the starter / alternator.
So, you mean remove cable (1) from jump post (2) then connect ammeter between (1) and (2) ?
