Home > Technical (L322) > cabin is too hot
yawlboy
United Arab Emirates 2009 Range Rover Supercharged 4.2 SC V8 Zambezi Silver
I bought the car at a BMW dealers, they are getting some warranty work done for me a J&P and I'll ask them to look at the heating then.
Post #15718 26th Mar 2010 12:01pm
dan_uk_1984
yawlboy wrote:
The left hand side of the drivers footwell gets hot to the touch. Any ideas?
There is a flat 4" pipe that runs under the carpet in this area that goes to the rear heater vents under the seats. If your heater is on this will get warm, if you have a lot of excess heat in the cubby box area it could be possible that one of the ducts to the rear blower has become loose. The center cupholder/ashtray should pull out to let you have a look in there and feel around for air flow.
Post #15719 26th Mar 2010 12:46pm
RREIRE
Ireland 2007 Range Rover Vogue SE TDV8 Java Black
Did you get it in little island? Blue06 vogue?
Post #15729 26th Mar 2010 4:30pm
adara
Romania 2019 Range Rover Vogue 2.0 PHEV Santorini Black
If you remove the side trim of the footwell (center console side) you will see that the plastic pipe going down gets extremely hot. I think the insulation from the trim isn’t enough to keep the heat away. When I removed the trim last time I put some self-adhesive foam on the pipe and the heat wasn’t transmitted anymore, there was a huge difference between the passenger non insulated side and mine. Maybe this is the solution if the warm trim is annoying…
Post #15748 26th Mar 2010 7:24pm
yawlboy
RREIRE - thats the one - pic in my gallery
thanks everyone for the advice. I'm getting to grips with it I think, I turned on the rear airflow today (kids had turned it off) and the temp is much better (still not perfect) but at least the cupholder isn't trying to boil things anymore.
Post #15760 27th Mar 2010 12:16am
