Home > In Car Electronics (L322) > shift-shaft noice
Norway
Norway 2003 Range Rover Vogue Td6 Adriatic Blue
shift-shaft noice
Hi
I have a shift shaft noice (clock tick tack) from my front right hand side door when motor is running (03v td6)
First i thought it was the cd changer but now i think the sound come from under neith the car.
Any ideas on what makes the noice?
Post #156251 9th Dec 2012 1:23pm
barracuda816
United Kingdom 2005 Range Rover Vogue SE Td6 Tonga Green
Hi, Does it make the sound when stationary or moving? Does the noise change with engine speed?
It may be a good idea to record the sound and host it on youtube or something.
Regards, Luke
Post #156356 9th Dec 2012 8:26pm
Norway
Hi
I can hear the Sound both while stationary and while driving. Ill try record it. Thx -03V td6
-72 Cadillac Coupe DeVille 7,7liter.
Post #156543 10th Dec 2012 8:02pm
Norway
http://www.youtube.com/watch?v=rOx3TyhMHBo&feature=plcp
Razz -03V td6
Post #156794 11th Dec 2012 10:13pm
Lloyd Barnes
United Kingdom 2008 Range Rover Vogue TDV8 Java Black
turn your indicator off....... glad I could help Laughing
I sometimes get a similar noise from what I think is the fuel pump... turn off, turn on again and its gone. Often it seems to be when I've run the FBH. Lloyd Barnes
Current
Crendon 427 Sideoiler Cobra in build... 7 litres of madness!
Gone
2008 TDV8 Vogue - Black with Ivory/Grand Black Lacquer
2008 VW Touareg 3.0Tdi
6.3litre Dax Cobra - 12.34 Second 1/4mile at 114mph Smile
Post #157349 14th Dec 2012 10:58am
Is it coming from a speaker?? Previously..
Post #157350 14th Dec 2012 11:01am
Norway
No, it not. Neutral -03V td6
Post #157613 15th Dec 2012 3:20pm
It could be the pump delivering fuel to the FBH
Post #157614 15th Dec 2012 3:22pm
Norway
Does anyone have a picture/drawing showing the fuel pump delvering unit and position.
thx Nor -03V td6
Post #157675 15th Dec 2012 8:33pm
The FBH feul pump (on '02 - '05 at least) is located on the rear subframe near the RH wheel. It is mounted in a rubber casing, so should only be ticking and not making any noise against the chassis.
Here is a diagram from RAVE. Doesn't help much I know.
Post #157687 15th Dec 2012 11:09pm
