Home > Technical (L322) > Heating
hempy18
United Kingdom 2004 Range Rover Vogue 4.4 V8 Zermatt Silver
Heating
Guys,
Blowers aint getting hot! Always cold air, never any hot air!
Been into garage and... New thermostat, New coolant and air lock removed, new cabin filter. Garage said it will blow hot at times then back cold Big Cry
Any ideas???
RR Vogue 54 plate 4.4 V8
Cheers
Hempy
Post #157338 14th Dec 2012 10:23am
What does the engine coolant temperature gauge say? If it's hot then I think your problem isn't with the coolant not reaching temperature.
Post #157352 14th Dec 2012 11:07am
hempy18
Sits as normal.
Expansion tank was empty day I gave car to garage so I topped it up. Did notice the float sensor in it was missing so obv going to need to monitor level or buy new one. Lads in garage said there was got air. But next day was cold.
Got it bk lastnight as I need it this weekend and cold air was blowing. Mate said it blows hot, turn engine of n then cold again.
Looked just now, coolant level was very low again, blowing cold air. Topped up...hot air.
No signs of any leaks tho! BAFFLED!!
Post #157354 14th Dec 2012 11:11am
hempy18
Thinking running it n keep topping up until all air is out the system????
Post #157355 14th Dec 2012 11:14am
Try running with expansion tank cap off for a while, may help to shift any air in the system ? (This advice not tested as an OK thing to do, just something I might try, others may confirm or otherwise?) .
Post #157357 14th Dec 2012 11:18am
question is ,hows the air getting into the system? ... - .- -.
Post #157360 14th Dec 2012 11:28am
If you are consistently loosing coolant and there's no sign of an external leak, which can be very hard to find on a hot engine, you have to consider the possibility of a head gasket failure.
You should consider having you garage pressure test your cooling system.
Head gasket failure could be consistent with no heat available.
Post #157362 14th Dec 2012 11:30am
hempy18
Cheers nicedayforit
Will give that a go next week!
Take it that a head gasket failure is leading to a remortgage???
Post #157363 14th Dec 2012 11:38am
While you are at the garage it would also be worth asking them to do a "sniff test" of your coolant for traces of carbon monoxide.
Between a pressure test and a sniff test you should be able to determine the size of remortage required. Smile
Shouldn't be too bad even if it is one of the head gaskets. Thumbs Up
I the meantime I would still be looking for an external leak.
Post #157368 14th Dec 2012 11:52am
hempy18
Well...ain't head gasket issue. Test done n not at fault!
Heaters were hot n cold all day today....
Search continues!
Post #157509 14th Dec 2012 8:49pm
Sticky, water control valves?
There are two water control valves for the air con which regulates the amount of water going through the matrix.
They are located on the right hand side of the engine, mounted on the vertical part on the inner wing(tucked down the side of the engine) if they arent opening to commands from the controls effectively you could have random heating. There is nothing that can't be fixed with a hammer😜😜
Post #157656 15th Dec 2012 7:05pm
hempy18
Cheers Northern, will give them a look over in the morning!
Coolant levels seems to be holding today. Just did a quick 10 mile round trip, some heat from some vents. Turned off engine to do a little temperature monitoring n all blowing warm air now after a restart. Few temp differences of a few degrees but no longer, some hot n some cold
Will see how they run 2mz!
Post #157667 15th Dec 2012 7:40pm
Norway
Norway 2003 Range Rover Vogue Td6 Adriatic Blue
Hi
I got the same situation. Did you solve this problem.
thx Rags -03V td6
-72 Cadillac Coupe DeVille 7,7liter.
Post #164858 15th Jan 2013 8:10am
ebajema
If you guys download the workshop manual PDF through the Wiki, you will see that the heating system is a number of flaps that direct the warm and cold air in different directions. You may have an issue with the actuators, connectors of actuators etc.
From what I remember, one of the actuators can be reached relatively easily from the LHD passenger side although you need to remove the glove box to get to all the screws. But have a good look at the workshop manual (2002-2005 model).
Good luck !! MY 2010 5.0 SC Galway green and sand interior!!
Post #164861 15th Jan 2013 8:18am
