Home > Maintenance & Mods (L322) > Sunroof rear drains
DavidP
Belgium 2006 Range Rover Vogue Td6 Bonatti Grey
Sunroof rear drains
Ok,
I thought that i had resolved/cleared these but from the sound [large gurggles travelling forwards above ones head when braking] I haven't.
I know that the rear drain tubes are routed and exit down the D pillar but are they visible from the underside without removing anything?.
If so where?
Thanks in advance
Post #157465 14th Dec 2012 6:16pm
You need to remove the plastic wheel arch liners to access the end of the drain tubes
Post #157476 14th Dec 2012 6:52pm
DavidP
47p2,
Thank you for the answer - this is where i am getting confused, the D pillar is behind the wheel arch. So does that mean that the drains route down the D pillar then come forward to the rear? of the wheel arch?.
Seems like a confusing design.
Post #157504 14th Dec 2012 8:37pm
as far as I know the pipes exit down the C pillars
Post #157512 14th Dec 2012 9:04pm
Post #157533 14th Dec 2012 9:59pm
DavidP
Thanks for the replys, I always thought that they drained down the C until reading Rave & a TSB [which i cannot now seem to find] which indicated D.
Perhaps it will remain a mystery...
Post #157566 15th Dec 2012 7:59am
Post #157571 15th Dec 2012 9:41am
Dolphinboy
Has anyone got a picture of the Bl**dy thing as I cant find it. THink this may well be the source of the problem of "wet boot" syndrome, just cant find the NRV to check! gggrrrrrr!
Post #157609 15th Dec 2012 2:16pm
DavidP
Dolphinboy - I agree, has anyone got a picture/photo or even a discription of where the rears exit. I have just spend the best part of 2 hours hunting around the aft of the beast but i cannot see any hoses/drain ends or anything that resembles.
Post #157668 15th Dec 2012 7:45pm
