![]() | Home > Maintenance & Mods (L322) > Reversing Light Replacement |
Just a quick note for those with cracked lenses or discoloured/aged lenses you can get brand new full units that take 2 minutes to fit from Dan @ Duckworths:
thanks for the heads up Gary...and whilst you're replacing the lens you can fit led bulbs as well.. ... - .- -.
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6424 ![]() ![]() |
Link Stan ! .
link?...they are bog standard 501's if memory serve me well.... ... - .- -.
Took pictures of my reversing bulbs today. was expecting "festoon types"?
A1GSS Member Since: 24 Dec 2010 Location: Saffron Walden, Essex Posts: 1973 ![]() ![]() |
You could try Disco3 Site Sponsors HIDS4U:
On the bay
Don't think the CANbus plays any part in the light bulbs...? Graham
Sure does, without canbus ready bulbs, or fitting resistors, the car throws an error on start up to advise bulb is broken! .
Yes, you need canbus leds they display on the message screen otherwise.
Possible this might be another LED strip job. I reckon the lens will come away from the backing in much the same way as the reflectors. Then drill small hole at bottom of backing piece for wires, stick two short White LED strips either side of the bulb housing, wire up to original wires, glue lens back on. Just a matter of whether this is bright enough? .
