Home > Maintenance & Mods (L322) > Fitting Battery Brain, electrical question
Thats it. Thumbs Up
Post #157647 15th Dec 2012 6:23pm
Very Happy Thumbs Up (slow learner - needs visual evidence) - the yuletide glasses don't help Confused .
Post #157671 15th Dec 2012 8:05pm
Thumbs Up Be interesting to see if you have a current drain.
Post #157674 15th Dec 2012 8:32pm
SteveyD
England 2003 Range Rover Vogue Td6 Bonatti Grey
Pretty much what everyone else has already said, I recently connected an Ameter in series with my battery, straight after ignition is turned off I was getting 0.54 A which then went down to 0.074 after 20 mins or so. Obviously my car has no battery drain.
You need to resolve you parasitic drain issue rather than hope fitting your "battery brain" to resolve any issue. I can tell you 100% that a partially flat 11.8v battery will not have the balls to turn over a cold & frosty TD6 that's been standing, yesterday this was proven and not even a top of the range snap on jump pack and 2nd battery had the grunt. In the end it took a discovery 3, Jump leads and 30 mins to get enough power.
In a nutshell go methodically about checking your circuits, Ameter in series, bonnet shut, pull a few fuses & lock car... Drink tea/coffee and check 20 mins later. Repeat x 49 if needed and then work out the faulty equipment / wiring (whilst shaking like a Censored dog on caffeine)
Post #157705 16th Dec 2012 12:27am
