Home > Maintenance & Mods (L322) > Iced up doors
Rambles
2011 Range Rover Vogue SE TDV8 Stornoway Grey
Iced up doors
so -6 overnight.....went to FFRR to open doors, and they were sealed shut with ice / frost. Eventually managed to open the front passenger door, and slip across into drivers seat.
any suggestions as to what i can put around the door deals to stop the doors freezing onto the frames?
Post #157718 16th Dec 2012 9:18am
mzplcg
I use car wax tp prevent water lying there but still get the odd frozen shut scenario. The easiest fix if it happens is to get a jug of warm water and trickle it round the seals. It all un-freezes in a few seconds.
Post #157719 16th Dec 2012 9:37am
jonlewis
2007 Range Rover Vogue TDV8 Buckingham Blue
My problem is freezing handle, so when I open the door the mechanism stays open and the door will not close. Looks like a greasing is required in the door cavity.
There is mention in the manual of putting something on the flocked top seal in winter. 2011 Stornaway Grey 5.0SC Autobiography
Post #157723 16th Dec 2012 10:12am
You can buy a product that you put on the seals and it rejuivinates the rubber and stops the icing. Not sure of the name it someone will come along in a min with it [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
Post #157743 16th Dec 2012 11:39am
SteveMFr
Site Sponsor
Take a look at your door opening once you've managed to yank the frozen door open. You'll see that you've just very effectively removed a good portion of the felt from the upper, outer door seal. These need to be sprayed with silicone spray every year to prevent this from happening - it is part of the service procedures. This sort of stuff starts happening when vehicles are not serviced regularly by competent, diligent persons (not an attack on anyone - just stating facts). If your RR was serviced recently and this was not done, go back and complain. The seals are not cheap and are vital in reducing wind noise.
RRC 2Dr, RRC 4Dr,
P38, and 2 L322s
Post #157744 16th Dec 2012 11:49am
CG-SC
2006 Range Rover Autobiography Supercharged Zambezi Silver
Gummi Pflege
http://compare.ebay.co.uk/like/25101201213...&cbt=y
Thumbs Up Stolen / Gone: 2006MY Supercharged LPG Autobiography - Zambezi Silver with Sand/Jet/Jet Oxford Leather.....
Post #157775 16th Dec 2012 1:02pm
JAYBOY
Silicon spray.
Wurth do a good one.
Ebay £8
http://www.ebay.co.uk/itm/Wurth-Silicon-Si...19ca17018f
Thumbs Up 2020 Porsche Panamera Turbo Hybrid (V FAST)
2018 JCW Mini Cooper
2018 Skoda VRS
Post #157776 16th Dec 2012 1:11pm
simon1233
silicone grease works well, cheaper/easier than the spray and is neater for application Thumbs Up
Post #157779 16th Dec 2012 1:27pm
TugRR
. . . . Vaseline . . . and lots of it Whistle
Thumbs Up Where do you go after one of these . . . ?
Post #157793 16th Dec 2012 2:44pm
Use this on our cars seals, never had one freeze up yet,
http://www.wickes.co.uk/silicone-lubricant-250ml/invt/432013/
Post #157799 16th Dec 2012 3:04pm
gummi pfedge is the stuff to stop the rubbers seals from sticking and as the the frozen locks, the only proper way to remedy this is to strip ot the locking mechanism and stuff a load of grease in there. i tried the spraying silicon grease into the lock but it didnt do the job... ... - .- -.
Post #157801 16th Dec 2012 3:05pm
Gummi Pflege +3
It's the proper way to deal with this one . 2008 MY Supercharged
Post #157848 16th Dec 2012 5:02pm
Budgie
I've read in a couple of places on the net that Vaseline is the one thing you shouldn't use on your doors seals.
Being patrolium based it'll will rot the rubber seals in a few years. Wink
I had the frozen door thing a few weeks ago and used a couple of dashboard wipes on the seals, does the same thing as the silicone spray, but less mess. Mr. Green
I also need to do the driver door handle as it's sometimes hard to pull open and needs a couple of tugs to get it too release, and that's when it's not frozen shut!!
Post #157881 16th Dec 2012 7:29pm
Rambles
have used the LR "genuine parts" silicon spray for the top of the door seals - both on the felt and the rubber.
is there any point in also doing the rubber seals round the sides and at the bottom?
Post #157962 17th Dec 2012 10:08am
Sounds like your cable behind the door card is about to go or is overstretched …. Whistle
Post #157963 17th Dec 2012 10:15am
