Home > Maintenance & Mods (L322) > induction kit for 2004 v8 undergoing 2012 upgrade
klf400
can anyone recomend an induction kit for my 2004 v8 as i under stand the 2012 head light will foul the air filter housing ? or perhaps there may be another way over this issue Bow down 1990 3.5 v8 defender
2000 4.6 v8 30th anniversary prins lpg
2004 4.4 v8 vogue prins lpg
2011 4.4 TDV8 Vogue
faultmate extreme
rsw allcoms
Autel 906BT
Gap iiD tool
Post #157889 16th Dec 2012 8:10pm
i think a K&N air filter is fitted on these conversions. ... - .- -.
Post #157891 16th Dec 2012 8:19pm
JohnnyDangerous
England 2002 Range Rover Vogue 4.4 V8 Java Black
I was told you just notch the bottom of the air filter housing. One day your life will flash before your eyes......................................make sure yours is worth watching!
Post #158089 17th Dec 2012 6:42pm
klf400
you may have a point there , i guess if its notched you can allways fibre glass it over to tidy it up and to keep it sealed Thumbs Up 1990 3.5 v8 defender
2011 4.4 TDV8 Vogue
faultmate extreme
rsw allcoms
Autel 906BT
Gap iiD tool
Post #158096 17th Dec 2012 7:28pm
JohnnyDangerous
Or leave it open to get that induction roar, I believe you can get a K&N to go in and they are designed to be used in the open, not inside an airbox so a small notch in the bottom of the box will be fine. Aternatively fit a universal K&N cone filter or you may be able to heat the air box up and 'mould' the notch in by hand, im doing mine soon so will report back. One day your life will flash before your eyes......................................make sure yours is worth watching!
Post #158108 17th Dec 2012 8:02pm
klf400
i am doing mine over christmas- i think i have all the bits , contacted k&n they said they dont do an induction kit but there may be a suitable cone filter to match the intake pipe size 1990 3.5 v8 defender
2011 4.4 TDV8 Vogue
faultmate extreme
rsw allcoms
Autel 906BT
Gap iiD tool
Post #158119 17th Dec 2012 8:28pm
JohnnyDangerous
You will definatly find one to fit, from experience get the largest you can but do not put it too low where it will get wet as K&N's don't do wet very well and if you ever end up going through standing water you dont want to suck it in. One day your life will flash before your eyes......................................make sure yours is worth watching!
Post #158123 17th Dec 2012 8:36pm
vnitos
South Africa 2016 Range Rover SVAutobiography 5.0 SC V8 Baltic Blue
bought my 2004 ffrr with 2007-9 supercharged conversion done - whoever did it put k&n cone air filter in - its working okay however i would like to put the filter inside a box as I'm sure it sucks in hot air which has a negative effect on both the performance and fuel economy
please let us know when you get a solution to this
Post #158301 18th Dec 2012 3:32pm
JohnnyDangerous
I have measured air temps on many cars on our dyno and do you know what sometimes its hard to find a diff with cold air kits etc, problem is you can feed as much cold air to the filter as possible but it then has to travel down a varying length of pipe (normally black) heating up all the way, its relatively easy to aim a pipe at the filter that is picking up cold air from outside the car if it bothers you. One day your life will flash before your eyes......................................make sure yours is worth watching!
Post #158303 18th Dec 2012 3:40pm
