![]() | Home > Duckworth Parts > Tail gate side part? |
| speedymarktd6 Member Since: 20 Nov 2008 Location: Worcestershire Posts: 727
Do you mean the black rubber covered cables that support the lower part when its open ? If so they are about £10-£12 each from land rover and easy to fit onto no6 Range Rover
| kingpleb Member Since: 07 Jun 2011 Location: Maybe here. Maybe there, I get everywhere! Posts: 8455
Nah he means the locking actuator |
| crookedm Member Since: 23 Sep 2012 Location: Heswall Posts: 698
Hi I mean the tailgate side clips directly under the rubber covered cables.
| mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 8000
Both of mine were bust when I got it.
Blimey!
Simple to do.
Cool sounds simple! Lets hope I don't break anything.
This is the part I need, the first one is the left hand one (the one i need) you can see a difference in that the top part when the tail gate is closed has a plastic part that I think stops the rain from running directly into it.
The plastic bit is the manual release lever for when the motor inside finally packs up |
