![]() | Home > Maintenance & Mods (L322) > Battery TDV8 |
JAYBOY Member Since: 17 Oct 2012 Location: South Wales Posts: 2204 ![]() ![]() ![]() |
I would take it to kwik fit first and get them to do a test on the battery.
If it ain't broke don't fix it |
STMVOGUE2010 Member Since: 23 Aug 2012 Location: Alloa Posts: 100 ![]() ![]() |
Already had it checked at Quickfit they said it was about 75% charging capacity able. |
Ok
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8776 ![]() ![]() ![]() |
Loads of info on batreries on here, but have a look for the euro car parts discount codes as they will get you up to 25% off the battery of your choice. There is nothing that can't be fixed with a hammer😜😜
Does yours still start and turn over ok without any sluggishness or hesitation? FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
^^^ Mine does |
If it does phone him up an start it. Turn it off and do it 2 more times an then say your off for a 5 minute drive to the shops |
stu Member Since: 04 May 2011 Location: Richmond North Yorkshire Posts: 927 ![]() ![]() ![]() |
use the FBH on a cold morning for half an hour and then try and start the it, that will let you know if the battery is in good health or not!! Current: TDV8 (3.6) RRS HSE
taskam Member Since: 01 Apr 2011 Location: Shandon Posts: 121 ![]() ![]() ![]() |
Yup, got the FBH running at weekend using remote. Fifteen mins trial run, starts ok. Let it run for half hour, not a chance...dead man's click like you said before. New battery to be ordered next...... |
GraemeC Member Since: 01 Jul 2012 Location: Chester Posts: 836 ![]() ![]() ![]() |
This is pretty much exactly what happened to mine - I usually run the FBH for 15 mins and its ok. Last Wed I ran the FBH for 30 mins because it was -3 outside and the car wouldnt start
steves025uk Member Since: 24 Oct 2012 Location: London Posts: 52 ![]() ![]() ![]() |
I get intermittent appearance of the digital time on the dash, how do you set it ? I also had 'dead mans click' after leaving the FBH on for 30 mins. (2007 FFRR Vogue SE) |
Hitting the button at the end of the indicator stalk cycles through the dash display options
Thanks very much.
