![]() | Home > Maintenance & Mods (L322) > More Range Rover cooling issues! |
JohnnyDangerous Member Since: 16 Dec 2012 Location: East Sussex Posts: 833 ![]() ![]() ![]() |
Sounds like it needs bleeding to me One day your life will flash before your eyes......................................make sure yours is worth watching!
You should be able to remove the drain plug and fit a new one
terry tibbs Member Since: 16 Oct 2012 Location: southampton Posts: 8 ![]() ![]() ![]() |
Thanks 47p2. I couldn't figure out for the life of me how to upload a photo! |
Rob2529 Member Since: 22 Nov 2010 Location: Wirral, uk Posts: 1470 ![]() ![]() ![]() |
I never use the rad drain plug. Easyier to just pull the small transmission hose off. Sounds like you have an air lock in the system. You need to have the heater controls set to full heat when doing it. The coolant system is a pain to bleed but just take your time. If the car starts to heat up shut it down and wait a bit. Not worth launching the engine over waiting a bit longer. [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
Thanks Rob. If the rain holds off (doubtful, I know) I'll give it a go this afternoon. |
Forecast is for lots of rain |
