Home > Wheels & Tyres > TOYO - 285/35 22
ricknayton
United Kingdom 2006 Range Rover Vogue SE Td6 Santorini Black
TOYO - 285/35 22
Hi guys,
Anyone know where i can get a set of TOYO 285/35 22 at all?
I have had a quote of £180 per tyre thats with fitting and balance. Would be grateful if anyone could advise if this was a good price or not as i've already got one 'A' hole and i don't need another ripped! Very Happy
Thanks
Post #158513 19th Dec 2012 4:28pm
a quick google comes up with about £165, so with v&b thats not a bad price.. ... - .- -.
Post #158515 19th Dec 2012 4:33pm
Yip, the place I use is £182.60 fully fitted.
Noticed they are rated E E 72... Not brilliant.
Edit... They are rated 106 for load... I am sure FFRR's should be 111... You should check that. Previously..
Post #158516 19th Dec 2012 4:34pm
ricknayton
Just nice to hear it off of someone in the know.
Thanks a lot for your help.
Post #158517 19th Dec 2012 4:34pm
Read my edit.. Previously..
Post #158518 19th Dec 2012 4:39pm
ricknayton
Thanks Contraband.
Ok, now i'm confused (doesn't take much)!
What would you recommend i have fitted?
Post #158523 19th Dec 2012 4:51pm
Can't really recommend anything, but 106 load index is for up to 950kg, my standard fit tyres were rated 111 which were for up to 1090kg... 'tis a heavy old beast is the FFRR, I would check that 106 is insurance friendly.... And safe.
Ps.. I am quite happy to be shot down if I am completely wrong here, my point was please check before you buy. Thumbs Up Previously..
Post #158525 19th Dec 2012 5:03pm
ricknayton
No, that's really helpful. Thanks a lot for that.
I will check before i make a purchase.
Very Happy
Post #158527 19th Dec 2012 5:07pm
wats39
Scotland 2004 Range Rover SE Td6 Alaska White
already looked into this as was looking at buying new tyres for my 22s. 106 rated tyres are fine unless towing then would need 109 or higher to keep the insurance companies happy at least. this is going by the maximum axle weights in the owners handbook. max front axle load is 1530kg, max rear is 1850kg which can increase to a max of 2050kg when towing.
Post #158548 19th Dec 2012 8:07pm
duckworthparts wrote:
7.5J x 18 255/60 R18 112 H or V- All
8J x 18 235/65 R18 110 H - Winter
8J x 18 235/65 R18 110 H N Y
8J x 18 255/60 R18 112 H or V N Y
8J x 19 255/55 R19 111 H or V- All
8.5J x 20 255/50 R20 109 V- All
just found this info of Topix in owners handbook
Post #158549 19th Dec 2012 8:13pm
I am no expert on this.. But when you are cornering, there must be a significant percentage of the axle weight transferred to the outside wheel. All the calculations are based on static weights. Also, if you hit a bump, the loading on the tyre will shoot up as well. I would say, best not to guess and calculate, go with the owners handbook or a tyre manufacturers guide. Previously..
Post #158550 19th Dec 2012 8:29pm
wats39
I agree with contraband but the manufacturers handbook doesnt list tyres for a 22" rim. i think most 285 35 22 tyres are 106 load rated tops with only one that i know of being a 112 and thats an 'achilles' or something. i would imagine the tyre manufacturers would have a large safety margin built into their tyres anyway so i wouldnt worry bout running a 106 rated tyre, after all it is load rated to take the weight of the ff so should still be legal????? i hope so 'cause mine are 106's Laughing
Post #158567 19th Dec 2012 9:22pm
ricknayton
Thanks a lot for the input guys.
I'm not too concerned as the wife drives it mostly! Laughing
Post #158648 20th Dec 2012 9:42am
Laughing Previously..
Post #158650 20th Dec 2012 9:43am
salb
United Kingdom 2007 Range Rover Vogue SE Supercharged Santorini Black
Hi guys,
Just took delivery of three tyres that I won on eBay,
Toyos 285 35 22, been looking fo a month, stan was right with that price,
Looked everywhere and ended up being very lucky I needed 2 and got 3 for
£260 delivered with 6-7 mm on them, but patience was the key, I was using a portable tyre
Compressor for 6 weeks using it every 2 days, you do get them on eBay some better than others,
And it cost me £15 a corner to put them on.
Sal RANGE ROVER OVERFINCHED 4.2 S/C
FRONT BUMPER O/F
REAR BUMPER. O/F
BOOT SPOILER O/F
22" ALLOYS. O/F
STAINLESS STEEL EXHAUST O/F
CARBON FIBRE WING MIRRORS & A PILLARS & CENTRE CONSOLE
Post #158653 20th Dec 2012 10:06am
