![]() | Home > Technical (L322) > Rotational related noise |
Contraband Member Since: 08 Nov 2010 Location: FIFE Posts: 3700 ![]() ![]() |
Sorry for the obvious.... But have you checked all the way round the tyre for stuck stones etc?? Does the noise change if you brake? Previously..
JAYBOY Member Since: 17 Oct 2012 Location: South Wales Posts: 2204 ![]() ![]() ![]() |
Can you hear it with the windows shut. 2020 Porsche Panamera Turbo Hybrid (V FAST)
Durham4416 Member Since: 10 Dec 2012 Location: Middlesbrough Posts: 248 ![]() ![]() ![]() |
To be honest I havn't tried listening with the windows down, I can feel it through the seat and the floor a little but nothing through the steering wheel, I'll give the tyres a good check over in the light tomorrow, could it be a wheel bearing? Thanks for the quick replies |
Don't worry about bearings, shafts etc until you have thoroughly checked the tyres |
Yes I'll give them a good check in the morning and report back, strange how its only at slow speeds, hope its nothing serious |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35837 ![]() ![]() |
jack that wheel up and rotate the wheel, this might find the cause.. ... - .- -.
Have you changed your tyre recently. |
I've only had the car about 4 weeks, front tyres are Goodyear wranglers and about half worn, I'll jack it up in the morning and give it a spin and a wobble and see if there's anything obvious |
Lloyd Barnes Member Since: 21 Apr 2011 Location: Shrewsbury Posts: 181 ![]() ![]() ![]() |
I had something similar on the rear recently. Sounded like a stone caught in the treads.
I'd read about the rear Calipers sticking, would explain the lower speed noise, I'll whip the wheel off and see if they are free, I checked the rear wheels for heat the other day just out of interest but they were both cold, maybe not a long enough run |
There's no difference in noise if I brake it stays the same until disappearing when I'm almost at a stop |
JohnnyDangerous Member Since: 16 Dec 2012 Location: East Sussex Posts: 833 ![]() ![]() ![]() |
I had this, turned out to be one of the brake dust shields had rotted around the bolts and was wobbling around rattling and touching the disk as it was going round. One day your life will flash before your eyes......................................make sure yours is worth watching!
Cheers ill take a look, cheers up to now everyone |
Common for the splash shield to break off and rub against the disc, easy to repair by removing the bolts and placing a large washer between the plate and the bolt |
