![]() | Home > In Car Electronics (L322) > Why 12V DC in cars? |
Rambles Member Since: 16 Apr 2011 Location: UK Posts: 845 ![]() ![]() |
would AC be better?
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35833 ![]() ![]() |
i remember when cars were positive earth... ... - .- -.
I have a a positive earth car |
ahebron Member Since: 01 Jan 2012 Location: The other Eastbourne Posts: 341 ![]() ![]() |
It is most likely because it was a happy medium between then current draw and voltage. Some of us will have experienced the old 6 volt cars and remember how feeble the electric system was. Nowadays modern cars are drawing huge current so everything has to had to be upgraded.
OK, form what I know of this, it originally was 6 volts and the wet cell was only used to power the lamps front & rear. In the early days these replaced the gas lamps which had been used until that time. At this point the engine's ignition system remained magneto based.
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8775 ![]() ![]() ![]() |
Im convinced. |
very informative Dom.. |
oldcro Member Since: 17 Mar 2012 Location: Shetland Posts: 359 ![]() ![]() ![]() |
I think it is the other way round. Tazers shock you with 50,00 volts yet, when I worked in a chlorine plant the cells had 300,000 amps at 4.5 volts running through large exposed copper bus bars. Loads of magnetism in the air but no fear of harmful electric shocks. |
JAYBOY Member Since: 17 Oct 2012 Location: South Wales Posts: 2204 ![]() ![]() ![]() |
Your sort of right. I'm an electrician by trade. there is a big difference between AC voltage and DC voltage. it would be a nightmare to have AC working on a car. DC from a battery is easy to deal with. A person could deal with touching up to about 48v AC with out really feeling it. I think other reasons they only use 12v is they use the body work of the vehicle as the earth or return path. 2020 Porsche Panamera Turbo Hybrid (V FAST) 2017 Range Rover Autobiography 5.0 V8 2018 JCW Mini Cooper 2018 Skoda VRS |
Double the volts half the amps, therefore starting current is less than if 12 volt. Remember watts = volts x amps so if either V or A increases then the other decreases. Less amps means less copper and smaller components. Another example is when people use inverters to convert DC to AC. A lot of domestic systems are running at 48 volts dc which means quarter the current of a 12 volt system. Adrian VW Amarok 2014 Highline auto |
Yep, so as said/surmised above, current is more damaging than voltage but the last line is that voltage provides the EMF (electro-motive force) which drives or powers a circuit. Without voltage a current can never flow.
Understood |
When I get my starship, will you be my Scotty, Dom, and look after the dilithium crystals |
Aye Captain, it will be a privilege Sir. Just remember, you cannae change the laws of physics! |
