Home > Technical (L322) > Starting issue-early stages-ignition switch maybe
netsonic Steve
United Kingdom 2002 Range Rover Vogue Td6 Epsom Green
Went out with some friends last night and when I went to leave around 11pm the RR would not start. Key in, all the normal clicks and whirs, key turns steering wheel lowers then a strange noise at the point of ignition hard to describe but no starter turning the engine, even more odd the headlights came on and air suspension inactive pinged at me...... all I could think of was to disconnect the battery earth let it rest for 10 mins re connect and try to start it........low and behold fired up, had to do lock to lock and all the faults cleared.............drove home dropped friends off but never turned the car off until I got home. When I turned it off at home tried to start it again and it would not start doing all as I described above........ Censored
Went to bed and in the morning I would try to start the RR as you do and would you believe it fired up first time and 3 times since then..........good in one way but annoying in another as I am wondering if I have the makings of an ignition switch fault that is intermittent at the moment. This fault appears to be well written about for L322's on the net.
I also read the thread http://www.fullfatrr.com/forum/topic14442.html from Johnte and it feels very much the same..
Having taken some of the centre console apart to be sure the location of the potential faulty item it appears if I do change this the whole centre consol needs to come out. What I was not clear on from the treads on here is if it’s a plug and play part if I change it or does it need the intervention of the LR diagnostic tool to set to your ignition so is it key specific.......it’s the part in the thread with the photo I linked on here if I’m correct in my assumptions that this is my issue. I guess it may be worth cleaning but not sure how successful this really is .........any thoughts................
Post #159533 23rd Dec 2012 2:29pm
Loose battery connection maybe, they have to be super tight
Post #159536 23rd Dec 2012 2:33pm
netsonic Steve
Battery's good, terminals very tight.......
Post #159550 23rd Dec 2012 2:57pm
JohnnyDangerous
England 2002 Range Rover Vogue 4.4 V8 Java Black
Clean between terminal and clamp? Also on the back and front of the +ve jump post the same. Check voltage engine off car asleep and running. As I have learntt if the battery is not 100% you WILL get problems. One day your life will flash before your eyes......................................make sure yours is worth watching!
Post #159554 23rd Dec 2012 3:01pm
Rambles
2011 Range Rover Vogue SE TDV8 Stornoway Grey
I have also had some starting problems recently....
when cold, it has not wanted to start on first push of button. But normally starts on the second go, has not required more than 3 go's.
when warm, not a problem.
have noticed it more when the fuel tank is low.....could this be an issue?
or could it be something like the glow plugs are not warming up quickly enough.....
Post #159987 25th Dec 2012 9:38am
