![]() | Home > In Car Electronics (L322) > Why 12V DC in cars? |
That's the same way round - you're both agreeing with each other. Had a small motorcycle when I was a bigginer years ago and that had a 6v battery. It was terrible. |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35854 ![]() ![]() |
so every ones agreed to agree then.... |
To make electricity understandable to people with no background in the subject, I usually use water hoses as an example. Voltage is equivalent to the water pressure and the current or Amperes is equivalent to the amount of water (=a larger diameter hose). Which is exactly what Dom was saying above with the electrons.
I think in the near future we could see some of the car manufacturers changing to a 24v system to cope with the massive array of accessories now fitted to most cars |
Ukdave104 Member Since: 26 Apr 2012 Location: Aberdeen Posts: 116 ![]() ![]() ![]() |
It's the current that will kill you not the voltage. The higher the voltage the easier the resistivity of the skin breaks down allowing a current to flow. If you limit the current flow as in a vandergraph generator then the voltage you can safely be in contact with is several thousand volts.
all i know is if you stick your fingers in that socket on the wall, it hurts... |
haveplan Member Since: 28 Oct 2012 Location: kent Posts: 7 ![]() ![]() ![]() |
Couple of things whatever the voltage used is stored energy in a cell, for lead acid that's approx 2 volts, hence 6ceels= 12v. other types of cell have different voltages. As for current, this flows in the opposite direction to the flow of electrons. As for safe voltage, it is considered that the safe touching voltage is 170 volts and this is how, for domestic electrical systems, it is derived that at 240 volts (domestic supply) a current of 30mA does not harm a person, hence the 30mA rating on RCD's and RCBO's. Gravity is a force attracting any solid object to another and this is why my golf balls always head for the trees |
