![]() | Home > Technical (L322) > Electrical gremlins have returned |
Katash Member Since: 10 Apr 2011 Location: Hereford Posts: 700 ![]() ![]() ![]() |
Check the connections on new battery are murder tight |
Dolphinboy Member Since: 08 Dec 2009 Location: Bristol Posts: 3251 ![]() ![]() ![]() |
+1 |
Nomad Member Since: 26 Oct 2011 Location: Ringwood, Hants Posts: 300 ![]() ![]() ![]() |
I just installed a Bosch S5 and I noticed that at full tightness the negative earth cable is not really tight on the post. This could be what's causing the problem above. I guess the Bosch post is slightly smaller than stock.
Difficult one - Probably get shot down for this but an idea would be using some flat braided earthing strap, cut to size and wrap that around the post before you put the clamp on ![]() Or alternatively modify the clamp with a dremel so it can close slightly more. (if you have the explosive disconnecter I wouldn't go dremel'ing anything tho) Edit: Just google'd the first suggestion and although I had a doubt it may be slightly dodgy atleast its not as bad as this suggestion:
Buz1500 Member Since: 05 Sep 2011 Location: Cumbria Posts: 369 ![]() ![]() ![]() |
I've just disconnected the battery and reconnected, tightening up as much as I can. Just taken it for a 20 min drive and no issues. Is is fixed? Too early to say I think but watch this space.
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8768 ![]() ![]() ![]() |
Sounds like you may have found the root of the problems.
OK. A bit embarrassed. |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35811 ![]() ![]() |
when in doubt, use a hammer...... |
So it wasn't an electrical problem after all |
It seems I've invented an electrical problem you can fix with a hammer! |
