![]() | Home > Technical (L322) > Air susp inactive after going through flood !! |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3986 ![]() ![]() ![]() |
Might be worth trying disconnecting the battery -ve terminal for 20minutes, reconnect and then steering wheel lock to lock with the engine running and see what happens.
Tuts Member Since: 24 May 2012 Location: Bishop’s Stortford, Herts Posts: 201 ![]() ![]() ![]() |
Forgot to put that in the first post, have tried that but no luck I'm afraid. |
Had this on mine. Went into a suspension limp mode where the compressor stops but the pressure regulator still works so basically if there is a weak point in your system or you drive over rough roads causing it to try and correct the suspension by letting some air out, it will end up dropping like a fart. Mine did this and on the bump stops it was near impossible to drive at anything but a crawl as every stone in the road would cause it jump or jut |
Oh great ! (Groan) so what you're saying is the OSF strut may be leaking slightly but it's probably not the cause, just noticeable now as the compressor isn't 'topping it up' due to the (hopefully unrelated) error? 2003 Vogue 4.4 V8 Java Black |
Probably!! the compressor could have died a death and the slow airbag leak can now be noticed.
Andpopse Member Since: 16 Oct 2010 Location: Bristol Posts: 100 ![]() ![]() ![]() |
Has your RR had LTB00077 done ? If not it could be this. I had this happen (its corrosion in the Compressor muffler). I only found the fault after using the ride height change to go through a deep puddle. Maybe worth getting it checked.
Sorry Andy I take it that's some kind of recall or similar? How would I find out if mines had it done? It's not on any of the invoices I got when I bought the car. 2003 Vogue 4.4 V8 Java Black |
wats39 Member Since: 08 Jul 2012 Location: fife Posts: 77 ![]() ![]() ![]() |
Might be worth checking the connections at the height sensors to see if they are dry. thats the first place i'd look. especially since it happened after driving through water. could even be the height sensors themselves have let water in through worn seals. '04 td6 se
mrd1990 Member Since: 01 Jun 2011 Location: N. Wales Posts: 267 ![]() ![]() ![]() |
Check for water in the spare wheel well, that's where the compressor is located. |
Dolphinboy Member Since: 08 Dec 2009 Location: Bristol Posts: 3273 ![]() ![]() ![]() |
+1 MRD.
Right, had the spare wheel out and it's bone dry (which is a rarity I believe! ), the rubber bung is still in place. Think I may have to go to the Indy and get him to scan it. I've had a look under each wheel, all of the height sensors appear intact although the wiring plugs look really badly protected from the elements - poor design? 2003 Vogue 4.4 V8 Java Black |
Is there no-one nearby with a hawkeye or anything to clear it for you? once its cleared and you give it some time the pump should come back to life |
Ajay(UK) Member Since: 02 Mar 2010 Location: Arundel, W. Sussex Posts: 608 ![]() ![]() ![]() |
I agree with wats39, I had the same issue on my old 2003 Range Rover when going through deep water. After a couple of days the height sensor dried out and normal service was resumed |
Thought I would add the result of this - airbag had split after being raised and had dumped all of the air out, result was a new strut was required, has been fitted and all is ok and back to normal now. 2003 Vogue 4.4 V8 Java Black |
