Home > Technical (L322) > Rotational related noise
Durham4416
United Kingdom 2003 Range Rover HSE Td6 Zambezi Silver
I'll let you know on the morning, an easy fix would be nice Smile
Post #159353 22nd Dec 2012 10:18pm
JohnnyDangerous
England 2002 Range Rover Vogue 4.4 V8 Java Black
When I found it I just took the bolts out and put a repair washer on and rebolted as I needed to us ethe car that day, ordered a pair of dust/stone guards but didnt fit them for ages as the repair held up fine. Easy to change as well and not expensive, the noise drove me mad sounded like the heat shields rattling and a stone caught in the wheel. One day your life will flash before your eyes......................................make sure yours is worth watching!
Post #159355 22nd Dec 2012 10:20pm
take care removing the bolts, they are 10mm and can sometimes be seized, a goot fitting hex is better than a multipoint
Post #159356 22nd Dec 2012 10:21pm
Durham4416
I'm not sure that will be it but things like that can cause noises you wouldnt expect so its worth a shot
Post #159357 22nd Dec 2012 10:22pm
Durham4416
Just had all 4 wheels off, tyres were clear of stones, all calipers moved freely and no uneven wear, on the NSF I found that the shield around the disc (as mentioned by a couple of you) was wobbling so I put some washers on and it's now nice and tight, I'll give it a run in a bit and hopefully that was the cause as I'm thinking of selling it, cheers everyone
Post #160278 28th Dec 2012 12:27pm
