![]() | Home > In Car Electronics (L322) > Aftermarket camera no colour? |
| stuboy00 Member Since: 09 Feb 2012 Location: Glasgow Posts: 251
Ok so bit of mixed info here now I was under the impression that the system was NTSC sure I read it on here? So now it's a PAL system that's fine I've no issues with the info but I just can't get my head round how the instructions say PAL/NTSC there must be some way for it to work properly i mean going from no camera to one that's B&W it's fine but I'd prefer it to be right lol F**K IT you only live once |
| Contraband Member Since: 08 Nov 2010 Location: FIFE Posts: 3700
It works in colour in test tho' so it likes something.. Previously..
| JOKER Member Since: 11 Sep 2008 Location: Sconnie Botland Posts: 15876
The camera that you bought is it for your year of vehicle |
It's an aftermarket camera joker
I'll be in tollcross tomorrow if you want to check mine against yours etc... Previously..
Thank for the offer m8 I don't really need to compair because its working I just need to find out what the story is if I can change the settings on the camera or the car?
| daveo Member Since: 21 Oct 2009 Location: london Posts: 2307
on the early pre touch screen they were ntsc cameras and went through the TV tuner with a trigger wire to switch to AV on the head unit, on the touch screen they connect direct to the head unit, now I have changed 2 or three cameras on the touch screens with the pal/ntsc after market cameras and never had a problem...
Hi daveo the picture is stable but with a sort of fuzz about it if that makes sense? The original camera had the same picture for a couple of days then went on the blink i thought it was just because it was on its way out? F**K IT you only live once |
Yea contraband exactly correct its an HD camera and the original went B&W just before it went on the bung? What's your thoughts m8 F**K IT you only live once |
First thought is an HD camera would not be compatible.. Not 100% on that.
Maybe but then when on the 753 test screen i get full colour and a perfect picture? F**K IT you only live once |
Correct.. Drambuie kicking in. |
post a link of the camera you bought V8 facelift Range Rover Autobiography 22" wheels.
