Home > Maintenance & Mods (L322) > Newbie with suspension fault
Nicka2311
Scotland 2005 Range Rover Vogue Td6 Java Black
Hi guys,
Firstly wanted to say that I'm a newbie to the RR scene but always wanted a full fat. After my fiancee and I had our little boy, I decided it was time to get rid of all the fast jap stuff (a 500bhp evo) and get a sensible family car for us and our husky.
I finally settled on a 55 plate Java Black Vogue with 65k on the clock, 20" Supercharged wheels (seen them on the evoque and sport) and every toy I think Land Rover could fit to one.
Anyway, onto the suspension issue. After the car has been running for a while I get a "suspension fault" warning on the dash but no associated symptoms. However, on 2 occasions the car has went into a limp home mode saying "suspension fault Max Speed 30mph" and the suspension height selection light have went out. If you simply switch the car off and on again this issue goes away, only once have I then had a "vehicle lifting slowly" message, but this was after about 5 minutes of the limp home mode, so I'm guessing the air suspension was completely empty as I heard it purging the air from the system and the height adjustment still works with no issues.
Is this a compressor fault or simply one of the height sensors has given up the ghost with all the wet weather and me not avoiding puddles no matter how deep?
How much do LR charge for a compressor and the sensors, I'd fit them myself as I'm a tech but was hoping one of the fountains of knowledge on here could help diagnose the fault.
Cheers
Nick
Post #160756 31st Dec 2012 2:06pm
At a rough guess i would say the compressor inside the boot under the spare wheel might be faulty , IIRC i don't think it is to hard a job to replace , see Dan@duckworths the site sponsor for a price on a replacement …
Could be wrong but that was the same fault i had on my old SC a few year back … Thumbs Up
Also welcome to the Madhouse Thumbs Up Thumbs Up ====================================
Post #160757 31st Dec 2012 2:11pm
Welcome Nick, were about in Scotland are you?
Post #160758 31st Dec 2012 2:14pm
Nicka2311
Cheers Joker, will message Dan and see what his prices are like. Happy to find out it's in the boot as I was expecting it to be somewhere on the slightly rediculous side. I'll get her into my unit and add that to the full paint correction and wheel refurb I'll be doing on her as no matter how much time someone spends on her, it just doesn't come upto the standards I offer for customers cars. It was "detailed" before I picked her up and it was still slightly Grey from all the swirl marks they simply Supaguarded over.
Nick
Post #160759 31st Dec 2012 2:16pm
Nicka2311
I'm from Grangemouth now bud, but I'm a Glasgow boy born and bred and still normally through that way to see customers cars and family.
Post #160761 31st Dec 2012 2:18pm
I'd recommend reading the fault codes after clearing them first as it could be a ghost in the machine...
Mine started to do the same and then the con red on the compression piston went pear shaped Sad
When you get a new unit would you be interested in flogging yours on at all for a few quid so i can purely have a good nose at it and see if its about to fail the same way mine did?
You may be able to get away with just removing the compression piston and motor, cleaning it all out(it fills with metal dust quite a bit i found!) and then some light emery paper over the piston ring and cylinder itself and a slight touch of some grease in there, high temp grease but not loads just a light light touch, to ensure a good seal Smile FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #160773 31st Dec 2012 3:03pm
JohnnyDangerous
England 2002 Range Rover Vogue 4.4 V8 Java Black
You can buy a rebuild kit for around £100 Thumbs Up One day your life will flash before your eyes......................................make sure yours is worth watching!
Post #160774 31st Dec 2012 3:04pm
PS can email you pics of how mine now looks in bits if it helps to point out the bits and bobs?
And the rebuild kit is NOT for the new ones as i have found Sad FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #160775 31st Dec 2012 3:05pm
JohnnyDangerous
My bad I thought it was not for the old ones !!!! The pics ive seen are for the one that 'looks' like an air compressor. One day your life will flash before your eyes......................................make sure yours is worth watching!
Post #160776 31st Dec 2012 3:07pm
The old compressor is much weaker in design compared to the new ones, I dont think many new ones have failed but the worst part is that generally when on full or extended height they run almost all the time for some reason...
And dont worry Johnny we all learn. Made me sad when i realised.. FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #160778 31st Dec 2012 3:14pm
JohnnyDangerous
Not had to touch that side of the car ...............................yet Very Happy All my problems have been up the pointey end. One day your life will flash before your eyes......................................make sure yours is worth watching!
Post #160779 31st Dec 2012 3:17pm
You'll be ok as you have the older one but at 2005 they changed over. I'd say if you have touchscreen you will have this compressor in the boot as i think its part of the ford parts overhaul but can't be sure as i know there was some mixing and matching at this age... FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #160781 31st Dec 2012 3:26pm
cliffy
2004 Range Rover Vogue 4.4 V8 Zambezi Silver
I've seen new ones for £250
Post #160843 31st Dec 2012 6:30pm
mjdronfield
Is the compressor not in the boot on all of them ?
Could be wrong.........
My 2003 car has it under the spare wheel, in the well......... 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #160846 31st Dec 2012 6:42pm
All in the wheel well on the L322, the P38 had it under the bonet i think. There is nothing that can't be fixed with a hammer😜😜
Post #160887 31st Dec 2012 8:29pm
