|  | Home > Technical (L322) > Servotronic Servo Valve |
| Paulhh Member Since: 23 Dec 2012 Location: Carrbridge Posts: 143      |
 Hi
|  31st Dec 2012 4:52pm |
| 47p2 Member Since: 05 Oct 2010 Location: Gone Beyond, Subaru Posts: 8048    | Search is your friend   | ||
|  31st Dec 2012 5:01pm |
| stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35880    | it regulates the steering fluid and is indeed an important part of the steering. ... - .- -.
|  31st Dec 2012 5:02pm |
| 47p2 Member Since: 05 Oct 2010 Location: Gone Beyond, Subaru Posts: 8048    | If you have the original valve fitted it will most likely be faulty, the new valve makes such a massive difference to the way the FFRR steers and well worth the £60 it costs   | ||
|  31st Dec 2012 5:09pm |
| Paulhh Member Since: 23 Dec 2012 Location: Carrbridge Posts: 143      | Thanks for that, I'll investigate it. Is there any way of knowing if it has the new type without removal and what are the symptoms? I have just moved from Discovery 2 to Range Rover and the steering is so much better already. | ||
|  31st Dec 2012 5:13pm |
| Jdd212 Member Since: 28 Sep 2017 Location: Rotherham Posts: 23      |
 Brilliant news as mine has the same original 1 in from when rack was fitted and now got the stiff wheel.checked power to the plug so hopefully it will cure the fault when i fit my new servotronic valve transducer 👊 | ||
|  28th Sep 2017 7:51pm |
| Jdd212 Member Since: 28 Sep 2017 Location: Rotherham Posts: 23      | Hi guys changed the servo valve today and no difference what so ever.if anyone else has the problem .refer to the bcm as I've checked power to the plug,checked fuses ,and checked the level in the fluid. Totally rounded it down the last thing causing the heavy steering and its defonatley the bcm under the passenger seat. | ||
|  2nd Oct 2017 4:37pm |
| stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35880    | its a process of elimination..the bcm is the next step..  | ||
|  2nd Oct 2017 4:41pm |
| Jdd212 Member Since: 28 Sep 2017 Location: Rotherham Posts: 23      | Totally agree on that Stan.pockets are getting realy empty too | ||
|  2nd Oct 2017 4:43pm |
| anorakmark Member Since: 18 Jan 2014 Location: Chatham Kent Posts: 121      | Hi Guys.
|  3rd Oct 2017 1:25am |
| Posting Rules
