![]() | Home > Technical (L322) > Trans failsafe Prog |
Katash Member Since: 10 Apr 2011 Location: Hereford Posts: 700 ![]() ![]() ![]() |
Battery voltage issue maybe? |
RRPhil Member Since: 22 Aug 2011 Location: Blackburn, Lancashire Posts: 1014 ![]() ![]() |
If you're thinking it could be a inhibitor switch fault then you should have a P0705 DTC stored in the controller. Might be worth selecting Neutral rather than Park when you start the engine to see if this makes a difference?
Paulhh Member Since: 23 Dec 2012 Location: Carrbridge Posts: 143 ![]() ![]() ![]() |
If I put the key in ignition and the car isn't started I can still activate the fault by wiggling the lever. It may be the battery I guess but it does seem more like a loose connection or something.
Still haven't checked fault codes, but if I put the gear shift into Neutral before starting I do not get the trans Fail safe error. I can then move the shift into drive and no further problems until I put it into Park and then get the fault. 2002 Vogue Epsom Green with Ivory Leather.
drakes Member Since: 26 Jan 2009 Location: Consett Posts: 373 ![]() ![]() ![]() |
Is this the sort of code an IIDtool can read and reset? 2010 3.6TDV8 Stornoway Grey/ Black interior - gone
You have an inhibitor switch fault
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16369 ![]() ![]() ![]() |
Do you have a battery charger or boost box? Even though your battery will start the car OK put your battery jump pack on before starting then do the same procedure to try and replicate the fault... If you cannot get it to do it then you know your battery maybe 10% below par ![]() Should give you a definitive answer about battery voltage ![]() |
