Home > Maintenance & Mods (L322) > Gearbox rebuild - TD6
ikilla2
2003 Range Rover HSE Td6 Stornoway Grey
Post #160702 31st Dec 2012 10:54am
JAYBOY
Top post
This is what the forum is for HAPPY DAYS
Thumbs Up 2020 Porsche Panamera Turbo Hybrid (V FAST)
2018 JCW Mini Cooper
2018 Skoda VRS
Post #160704 31st Dec 2012 11:05am
That is cheap.
Post #160928 1st Jan 2013 10:12am
mjdronfield
Wonder if the price varies depending on whats wrong, or whether items are replaced irrespective. Probably the latter if he is offering a warranty.
Good price indeed. 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #160943 1st Jan 2013 11:37am
SteveMFr
Site Sponsor
Does not sound like a full rebuild - the parts alone with a rebuilt torque converter cost about that.
Sounds like you have a new valve body with 'hardened valve bore inserts' and fluid. If your only prob was an inoperative valve then this will def have gotten you going again. Risk factors for the future are:
- worn TCC lining
- worn pump
- and above all crud floating throughout the transmission. The stock filter in an auto box is on the suction side not the pressure side so it cant be made too fine or you'd end up starving the pump. This means that most of your finer particulates will pumped through the box over and over again.
I am not saying that this is not a good repair. If the rest of your gearbox is in good shape this should keep you going for a while. It is not the same as a full rebuild, tho.
RRC 2Dr, RRC 4Dr,
P38, and 2 L322s
Post #161164 2nd Jan 2013 10:34am
aneurysm1
2010 Range Rover Autobiography TDV8 Cairns Blue
glad your happy with it buddy!
Post #161408 2nd Jan 2013 10:47pm
