![]() | Home > Technical (L322) > Smokie TD6? |
adara Member Since: 09 Dec 2008 Location: Eastern Europe Posts: 875 ![]() ![]() ![]() |
In Microcat the valve breather is called filter assy, part no. 8510298. I wonder if it's the same as the BMW part no. 11127799224? |
Found the part from BMW, it's no. 11127793163.
jope Member Since: 04 Apr 2009 Location: Reinsvoll Posts: 43 ![]() ![]() ![]() |
hi thats great |
jayro Member Since: 13 Dec 2012 Location: Wollongong Posts: 1 ![]() ![]() ![]() |
I too had issues loosing bits and used bluetac to hold the socket set and Hex head from falling...
My TD6 is in standard tune but doesn't smoke at all even when booting it. I'd try a fuel injector cleaner and possibly squirt some fairy liquid up the exhaust and then fill it with water and leave it a few hours to eat at the soot. Then start the engine and don't touch the accelerator.
33CHINACARS Member Since: 14 Apr 2011 Location: Tyrendarra, Victoria, Australia Posts: 381 ![]() ![]() ![]() |
Should have replaced with Pt No 11127799367. Updated part . Never have to replace again.
ahebron Member Since: 01 Jan 2012 Location: The other Eastbourne Posts: 341 ![]() ![]() |
I have posted about this before so a search will help you.
frikkadel Member Since: 09 Mar 2016 Location: joburg Posts: 56 ![]() ![]() |
Brake fluid in the exhaust is much better. Burns the soot out but only when hot. people will think your engine has blown with the amount of smoke. |
