Home > Technical (L322) > Numpty Question about the dash display
JohnnyDangerous
England 2002 Range Rover Vogue 4.4 V8 Java Black
Ive only had the FFRR for almost 3 years and in all that time I have not managed to use the display function on the dash, ie stopwatch, Timer etc, I can scroll thru and get time, radio station etc to show but when I scroll to stopwatch how do I intiate it, I did find that by holding the button in on the selector lever it brings up a display on the nav screen that enables me to spec what functions I want shown on the digi display. Embarassed One day your life will flash before your eyes......................................make sure yours is worth watching!
Post #161652 3rd Jan 2013 7:13pm
JohnnyDangerous
No one else use this either?? One day your life will flash before your eyes......................................make sure yours is worth watching!
Post #161756 4th Jan 2013 12:19am
Remember using this on my old SC but Censored if I can remember how I did it ====================================
Post #161767 4th Jan 2013 12:53am
JohnnyDangerous
Ive tried everything !!!! One day your life will flash before your eyes......................................make sure yours is worth watching!
Post #161768 4th Jan 2013 12:55am
mjdronfield
My car is in the bodyshop at the mo, so can't test. Not sure if its any different running through a Mk4 Nav......
...anyway, I don't need a stopwatch to know my Td6 does 0 to 60 in a shade under 5 seconds Rolling with laughter
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #161782 4th Jan 2013 10:16am
Richcl
United Kingdom 2002 Range Rover HSE Td6 Zermatt Silver
I'm sure I read in the owners manual that the stopwatch function (altough appearing on the dash) is not available on some models.
Post #161784 4th Jan 2013 10:19am
Errr...
Have you looked in the handbook? Audio, tv and navigation supplement.
It describes how to set the stopwatch function in there.
Post #161785 4th Jan 2013 10:22am
JohnnyDangerous
I would but im stuck on the couch and the handbook etc is 40 miles away at work. One day your life will flash before your eyes......................................make sure yours is worth watching!
Post #161787 4th Jan 2013 10:24am
Richcl
nicedayforit wrote:
Errr...
Er... yes, Else I wouldn't have said what I said...
Post #161788 4th Jan 2013 10:33am
My post wasn't directed at you. Thumbs Up
Post #161789 4th Jan 2013 10:35am
The stopwatch is only via the centre screen, it doesn't appear in the dash binnacle.
If you press and hold the indicator stalk button the centre screen shows all the options for you to select to flick through with the stalk, via the dash (Av speed, MPG1,2 etc etc)
To use the stopwatch you select it from the screen navigation. There is no memory function, once the ignitions goes off, it is wiped. I rarely use it. Discovery 4 HSE
Post #161795 4th Jan 2013 10:53am
JohnnyDangerous
It appears in my binnacle along with 2 timers. One day your life will flash before your eyes......................................make sure yours is worth watching!
Post #161806 4th Jan 2013 11:20am
this site might help with manuals etc..
http://www.landroverweb.com/landrover/pdf-land-rover-manuals/ ... - .- -.
Post #161807 4th Jan 2013 11:25am
I am going to go and see if mine does that, pretty sure my TD6 didn't either though. Maybe it was a throw-over from the old BMW systems - I had it in my 528 and M5. Discovery 4 HSE
Post #161812 4th Jan 2013 11:45am
JohnnyDangerous
If I hold the button in that you use to scroll the display then all the options come up on the nav screen, you tick each you want and save and thats what comes up when you scroll through the binnacle display, I have time,date,radio station or cd,stopwatch, timer1,timer2,range,av speed. One day your life will flash before your eyes......................................make sure yours is worth watching!
Post #161814 4th Jan 2013 11:58am
