Home > Maintenance & Mods (L322) > Headlight bulb replacement.
ambulancekidd
Scotland 2005 Range Rover Vogue Td6 Oslo Blue
SWMBO has just come home & told me that the NS dipped headlight bulb (xenon) on our 2005 (not face lift) FFRR Vogue has blown. I've previously tried to remove the headlight units to replace sidelight bulb & failed miserably. I'm out in a cold sweat worrying about changing the headlight bulb now.
Where is best to buy one of these bulbs & are there any tips that I should know about? Rolling Eyes
Many thanks in advance.....Robert. The reason women's minds are cleaner than a mans mind is that women change their minds more often!
When women say fine a mans in deep doodoo as fine has so many meanings.
Post #161664 3rd Jan 2013 7:40pm
bulbs can be replaced without taking the headlight out..bulbs can be brought from ebay for about £18 'ish and i would replace as a pair and keep the other good one as a spare.. ..try 6000k ones which give a whiter light.. ... - .- -.
Post #161669 3rd Jan 2013 8:05pm
ambulancekidd
Many thanks Stan, it doesn't sound so daunting as I'd thought. Strange thing is that the light was working when I went out to check it. I'll order two bulbs up this evening & fit them asap. The reason women's minds are cleaner than a mans mind is that women change their minds more often!
Post #161722 3rd Jan 2013 10:30pm
And if IIRC, on the >2005 pre facelift, you can't remove the headlight without first removing the sidelight, you can't access one of the securing bolts on the outer lower side of the headlight.
Sidelights should come out easy enough on their own Rolling Eyes .
Post #161743 3rd Jan 2013 11:31pm
JohnnyDangerous
England 2002 Range Rover Vogue 4.4 V8 Java Black
Stan, what heat range are the stock bulbs??? One day your life will flash before your eyes......................................make sure yours is worth watching!
Post #161758 4th Jan 2013 12:24am
stock bulbs are 4300k which give a slight yellowy tinge, 6000k are more whiter...
there is an argument that the stock temp is a more stronger light but i didnt find that, in fact my 6000k's seemed brighter.. ... - .- -.
Post #161808 4th Jan 2013 11:28am
JohnnyDangerous
I prefer the higher temps like 6000 and 8000, do you have a part/model number for the bulb? Or a link to e.bay seller. One day your life will flash before your eyes......................................make sure yours is worth watching!
Post #161818 4th Jan 2013 12:10pm
just standard d2s bulbs but they must have the metal anti vibration strips on them other wise they wont fit properly..
edit, the bulbs are d1s type in the facelift i believe.. ... - .- -.
Post #161821 4th Jan 2013 12:14pm
JohnnyDangerous
Are the bulbs the same part No in 2010> One day your life will flash before your eyes......................................make sure yours is worth watching!
Post #161840 4th Jan 2013 1:11pm
dunno, you got a conversion then? ... - .- -.
Post #161842 4th Jan 2013 1:15pm
JohnnyDangerous
Suuuure have BRO, I is goin all Council Estate wiv me ride innit Whistle Just need to get a pair of lights off of Craig which im just waiting a reply on. I have the bumper and grill at the bodyshop and rear lights and side vents are already in place just need one more 2012 door card to complete the interior then a few dress up bits and im done. One day your life will flash before your eyes......................................make sure yours is worth watching!
Post #161858 4th Jan 2013 3:20pm
sounds like a very interesting project .... Thumbs Up ... - .- -.
Post #161859 4th Jan 2013 3:23pm
JohnnyDangerous
Thanks Stan, so far ive done pretty much all the piano black I can inside inc heated piano black steering wheel, MKiv DVD Nav, re connolised the seats from sand to satin black as well as the lower dash and had the 20" RR rims reconned and finished in black chrome, hopefully by next week Ill have my IID tool and Intravee 2 as ell as the stuff I need to do the front end conversion, hopefully im well enough to do this myself at the workshop from my wheelchair, but I do fancy using some 6-8000K bulbs for that diff look. One day your life will flash before your eyes......................................make sure yours is worth watching!
Post #161862 4th Jan 2013 3:36pm
Like this for standard fitting (but at 6000k) ?
http://www.ebay.co.uk/itm/Range-Rover-2002...3355cc423f .
Post #161884 4th Jan 2013 5:11pm
JohnnyDangerous
Yes but for 2010> council estate headlamps One day your life will flash before your eyes......................................make sure yours is worth watching!
Post #161886 4th Jan 2013 5:12pm
