![]() | Home > Technical (L322) > Air Susp Inactive |
woodchopper23 Member Since: 20 Jan 2012 Location: cumbria Posts: 259 ![]() ![]() ![]() |
Hi folks,
Just looked at a post from last week, seems I could check the airline going to the air strut as well, just to be sure before I opt to order a new bag to replace the old bag. |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6423 ![]() ![]() |
Diagnostics will clear the hard fault on the Air Suspension (All Comms/IIDtool etc). You should then get a loud hiss from the offending airbag.
Joe,
I wonder if one of the smart phone OBD11 apps would work to fettle the fault? Due to lack of diagnostics I think ill end up doing a visual insp, then just getting a replacent bag and hope for the best ! MY2010 TDV8 Vogue Ipanema Sand
I've got the RAC Allcoms diagnostics if it's of any use. |
Hopefully contraband, ill be checking the airline before I order a new bag ... Nice day for it , thanks for the offer. I'll see how I get on and if it doesn't clear, ill pm you and take a drive up to see you when its convenient |
Well I changed the leaky bag and had to get the hard fault (no lights on EAS control in dash) cleared at a garage (thanks for the offer nice day for it, but needed to get it done ASAP due to the car riding on the bumps stops and behaving terribly),
How unlucky is that for two to go at the same time |
The first thought that went throught my head was " I bet they have stuck a bradawl through it " when the garage cleared the fault , but the more I've thought about it , its most probably the fact that they are original from 2002, so they have lasted a good time .
No problem. |
