Home > Technical (L322) > Occasional "HDC Inactive" Message
JW911
Hi,
New to FFRR but occasionally I get the "HDC Inactive" message with a chime if the car has been left for a day or two. It clears immediately. Having done a bit of research, it may indicate the battery is on the way out. Does this sound about right?
JW911
Post #1627 9th Dec 2008 12:52pm
dont think the battery is on its way out , i had this problem about 3 times when i first got the car and on each occassion it was cleared via LR plugging in the laptop as it was by-passing one of the brains in the car , and have not had aproblem in 3 year since .
Part and parcel of having a Bamber Gascoigne Car...................... Thumbs Up ====================================
Post #1628 9th Dec 2008 4:50pm
HDC stands for Hill Descent Control and sometimes these types of error message come up. They don't always mean something is wrong, just a sensor tripped which then shuts something off.
I've had this, and it goes way after a reset (turn on and off again)
Nothing to worry about unless you were off-roading and using HDC at the time! Discovery 4 HSE
Post #1629 9th Dec 2008 6:12pm
speedymarktd6
United Kingdom 2010 Range Rover Vogue SE TDV8 Santorini Black
i tend to find this theary can be applied to most messages onto no6 Range Rover
Everyone needs a hobby
Post #1650 10th Dec 2008 8:30pm
ken
United Kingdom 2018 Range Rover SVAutobiography 5.0 SC V8 Santorini Black
Think of a reset as CTrl AlT Del Whistle
And low voltage is normaly the issue here
Just about to commision a dual battery set up
Post #1656 10th Dec 2008 10:22pm
JW911
I know all about it. My office is an Airbus A320. Rolling Eyes
Post #1914 20th Dec 2008 12:03am
Yeah when you have two 21AE V2500 engines each giving 26,500lb of thrust trying to lift something that weighs over 92,000lb its a good sign you know CTRL ALT DELETE................. Bow down Thumbs Up
Post #1915 20th Dec 2008 12:40am
fisha
The HDC message could possible be down to one of the front cables for the ABS sensors. These can rub against the inner side wall of the front tyres to the point the metal cores are exposed or even cut right through.
Once the cable is broken, the ECU gets no signal from the sensor and so cant sense the wheel turning, and it effectively looks like the wheel is stationary, which for HDC control would cause all sorts of problems .... so it disables HDC.
The car knows there is a problem as all 3 other wheels will be turning.
I'm about to take the cable off and repair it using a semi-bodge method of repair, which hopefully should sort the issue out. If i can, i'll post pictures. V8 or else ...
Post #7415 25th Sep 2009 9:42pm
JW911
It was definitely battery related. Once the battery was replaced a few months ago, the message stopped appearing, as did one or two other little electrical jitters.
I've just driven the car today after it had been parked up for nearly three weeks and what happened on start-up? "HDC Inactive". A drive to give the battery a boost has solved the problem.
Post #7636 6th Oct 2009 4:04pm
