![]() | Home > Technical (L322) > Trans Failsafe Prog - Another one!! |
| SKOT Member Since: 24 Oct 2012 Location: Milton Keynes Posts: 792
Hi All,
| JohnnyDangerous Member Since: 16 Dec 2012 Location: East Sussex Posts: 833
I would say you still have a voltage problem, have you had a multimeter on it? One day your life will flash before your eyes......................................make sure yours is worth watching!
Hi Mate,
| Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6434
The Air Suspension can bus fault is "normal" doesn't appear to have any impact on anything |
But he is getting a Bat undervoltage warning. that would say to me a problem somewhere with drain or faulty battery. reading 12.2v is quite under charged. One day your life will flash before your eyes......................................make sure yours is worth watching!
Hello Chaps,
| stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35875
might not be the answer but if the obd cover isnt shut properly that causes a current drain.. ... - .- -.
Hi Stan,
knowing the traits of the fullfat you'll probably find it sorts itself out on its own.. |
I hope so, Stan. Every time I hear that "bong" I leap out of my skin wondering what is going to be next!!
| ebajema Member Since: 24 Mar 2011 Location: New Plymouth Posts: 4782
One thing you could try (and this seems to be my favourite advice on all electrical problems if you see my responses to similar posts |
We don't normally see a TFS message/bong/fault when there is a battery/voltage problem normally the HDC/ABS chain of events (or non events) .
Joe90 - If TFS is going to happen it happens before that...............As soon as the "Pre Heating" sign goes out so before I've got anywhere near changing gear. That aside...........I started from cold this morning and BONG - My heart sank until I peered through the broken pixels to see the external temperature warning. The FF has behaved faultlessly all day - 200 miles. I had 3 more Bongs, all external temp. In contrast I was getting the TFS every few minutes a days ago. Hurrah! Thinking back, all I've done is secured the battery earth (rubbed the terminal and connector with glass paper and made a really tight connection) and cleared the fault codes with Allcomms. The only other thing I can think is the new battery (OEM part) has never really had a really good, deep charge that the past 400 miles will have put in but I think I'm pulling at straws there. I'm not counting my chickens yet, so please your fingers crossed for me chaps! Many thanks for all the advice so far. 2006 4.2 SC 2019 Renault Zoe Dynamique Nav
| All times are GMT |
