Home > Technical (L322) > Air Suspension Inactive after D/S Front Bag Blew!
R4NCE
2002 Range Rover Vogue Td6 Zambezi Silver
hi all,
Yesterday front drivers side air suspension bag blew on my L322. Big Cry
Changed it today and now it looks like a dog Censored ! Anywhere in the North East which could re-calibrate the suspension?
Cheers James
Post #163022 9th Jan 2013 4:00pm
ebajema
That is a bit strange, mine was hanging with its nose on the ground when both front bags were replaced but needed no electronic "help" to get going again. I suggest to disconnect the battery clamps, hold them together for at least 10 secs. to drain the ECU memories and then reconnect to the battery. MY 2010 5.0 SC Galway green and sand interior!!
Post #163035 9th Jan 2013 4:46pm
Durham4416
United Kingdom 2003 Range Rover HSE Td6 Zambezi Silver
Hi mate try this item no on eBay, he only quoted me £40 to recalibrate my suspension as mine sits a little low at the rear, he is in Durham, unless there's someone on the forum who has the diagnostics to do it , the only reason I haven't paid to have mine done is because I'm not 100% it will cure it then It will be a waste of money so I was hoping someone had diagnostics who could help me Smile
Post #163051 9th Jan 2013 5:30pm
mrd1990
United Kingdom 2002 Range Rover HSE Td6 Oslo Blue
Have you driven the car since changing the air bag?
The height sensor should automatically correct the ride height on each corner, try driving it a few miles before getting it recalibrated.
Post #163080 9th Jan 2013 7:03pm
Tesh
United Kingdom 2004 Range Rover Vogue Td6 Java Black
Ive used a guy in Haswell on numerous occasions for allsorts of jobs including suspension adjustments
He used to work for a main dealer but decided to set up on his own
His name is Wil and his number is 07866121695
Post #163088 9th Jan 2013 7:29pm
Durham4416
That's the guy I linked to off eBay
Post #163091 9th Jan 2013 7:40pm
SteveMFr
Site Sponsor
There is no such thing as an automatic recalibration . And you won't need it if all you've done is replaced the strut.
You have a critical fault ( hard fault) logged and the EAS shut itself down till you get this cleared. Even the dealer usually only charges GBP 40 or so for this. If you find a nice Indy, you might get it done for free.
RRC 2Dr, RRC 4Dr,
P38, and 2 L322s
Post #163200 9th Jan 2013 10:47pm
Tesh
James
Ive got a plug in tool that resets the faults on the suspension
I live local to Durham if you want to use it
Paul
Post #163300 10th Jan 2013 11:40am
Durham4416
Cheers mate but I think it needs recalibrating, I don't think it has any faults it just sits about 4cm lower on the back, might be worth plugging it in first to see if there is a fault though ?
Post #163356 10th Jan 2013 3:41pm
the back being lower than the front is normal afaik.... ... - .- -.
Post #163358 10th Jan 2013 3:49pm
Durham4416
Yeah I think it's supposed to be 10mm lower, i used the guide on here and it's definiey to low at the rear, I'm hoping a recalibration is all it needs as the suspension goes up and down exactly how it should and it doesn't drop over night
Post #163363 10th Jan 2013 4:06pm
i suppose 4cm is a bit much .... Thumbs Up ... - .- -.
Post #163371 10th Jan 2013 4:26pm
