Home > Technical (L322) > Smoke from filler cap! |
woodchopper23 Member Since: 20 Jan 2012 Location: cumbria Posts: 259 |
Yes the back left of the engine. Have a look tonmorrow and you will see what I mean. Sorry no link online, but do a search here for.pcv repair and somewhere there is a link to a video of a yank mechanic swapping the pcv, but I don't think he goes as far as the metal pipe . You will see it bolted to the bottom of the sump with a banjo or you will see the top of it from the back left of the engine once the cyclone/ condensor is moved. It's fairly simple once you get eyes on it. Only trouble is you have tobdrop engine oil to get the metal drain pipe off it it does turn out to be blocked MY2010 TDV8 Vogue Ipanema Sand
9th Jan 2013 11:00pm |
Durham4416 Member Since: 10 Dec 2012 Location: Middlesbrough Posts: 248 |
Ok I see, iv replaced a crankcase breather for the later style vortex type on my 320cd in the past so I will be able get that far, so once I remove the crankcase breather in looking for a metal pipe that goes from the bottoms of the housing to the sump, then if I try blowing down this pipe and I can hear the oil 'gurgle' then its clear, if its blocked I need to two over and clean out? Think iv got it, you mentioned a few other pipes aswell, do these also run from the crankcase breather housing? Thanks |
9th Jan 2013 11:06pm |
Look at this link
9th Jan 2013 11:14pm |
I've found it from the pcv wiki
9th Jan 2013 11:18pm |
The filthy pipe is labeled as 6n 664 in the drawing.
9th Jan 2013 11:20pm |
The TD6 doesn't have a PCV |
9th Jan 2013 11:35pm |
9th Jan 2013 11:36pm |
Ah. Is it worth checking the crankcase breather and pipes coming and going from it still though? Although an awkward job it seemed more inviting than a head gasket or worn piston rings |
9th Jan 2013 11:42pm |
