Home > In Car Electronics (L322) > Amp socket burnt out, easy to replace?
mrd1990
United Kingdom 2002 Range Rover HSE Td6 Oslo Blue
Obviously the amp and the plug will have to be replaced, with regards to the plug how easy a job is it?
From what I can see, I'll need a new wiring loom to the head unit? or is there another solution?
Post #163354 10th Jan 2013 3:34pm
I'd say some water has caused that so best to identify the route cause if you haven't already done so.
Getting another socket will not be easy as it will be part of the loom. Best to try some breakers and then splice in the new one Sad not an easy job with all the wires but going one by one with a soldering iron should do it neatly Smile FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #163359 10th Jan 2013 4:01pm
If you were to carefully take the plug to pieces and note the position and colour of each wire connected to it shouldn't be too dificult to fit a new plug to the harness, assuming the harness is long enough to reach to the amp socket with a new plug fitted.
The biggest problem you may have is finding a new plug.
I would be inclined to try and find a scrapped car with the same set up and cut the plug off the harness leaving about 200mm of cable attached.
Then cut off your old plug and fit the recovered plug to the ends of your harness by jointing the cables by colour. Not difficult.
Where to find a scrapped car is the problem.
Another option is a harness replacement, how far does the harness go until a plug / socket is fitted?
Good auto electrician should sort you out.
Post #163362 10th Jan 2013 4:06pm
DMRR
South Africa 2009 Range Rover Westminster TDV8 Stornoway Grey
Try VWP - vehicle wiring products for a new connector.
http://www.vehicle-wiring-products.eu/VWP-...mepage.php Land Rover Addict
XXXXXXXXXXXXXXXXXXXXXXX
Previous
XXXXXXXXXXXXXXXX
2009 5.0V8SC Autobiography
2006 4.2V8SC Autobiography
2004 4.4V8 Vogue
Post #163372 10th Jan 2013 4:27pm
mrd1990
Does anybody know what the part number is?
Workshop manual says "Amplifier Harness Connector C2077" no hits on google Confused
I'm wondering if it would be easier to put in a new loom, don't mind spending £100 but I have a feeling it could be £1000+ Censored Big Cry
Post #163566 11th Jan 2013 1:40am
SteveMFr
Site Sponsor
Yes, the loom is ridiculously expensive and covers half of the back of the car meaning installation is also ridiculously expensive. And finding OEM connectors such as this new is extraordinarily difficult. That is why headlight plugs for facelift conversions were selling for GBP 65 or even more on ebay...
It's hard to tell from the pic, but if the harness connector can't be saved, I'd try to get a breaker to clip off the connector with a couple of inches of wire left and graft the plug back in. And if the amp still works, the cheapo alternative would be to solder wires to the board the connector sits on and pic up a couple of generic multi-pin connectors at an electronics store and make your own connection.
What happened? It doesn't really look like water ingress - just a very serious short. Shocked
RRC 2Dr, RRC 4Dr,
P38, and 2 L322s
Post #163577 11th Jan 2013 8:30am
mrd1990
It was water ingress, 5 days of continuous rain over Christmas Big Cry
Well a quick email this morning to a breakers yard and I have a new plug with wires attached on the way, £15 Cool
Just a matter of joining up the wires, the big question is what else is damaged, I'm 99% sure I'll need a new amp but the head unit isn't coming on. The fuse did blow so fingers crossed that saved it.
Thanks for the help, I'll keep the thread updated Thumbs Up
Post #163752 11th Jan 2013 5:37pm
Dolphinboy
MRD, I have a non-working one of these which you can have - the only damage is one of the spikes in the socket snapped under corrosion, meaning I couldn't get sound on one side of the car; otherwise it works. You may be able to swap them over. PM me if you like. Thumbs Up
Post #163785 11th Jan 2013 6:43pm
mrd1990
Thanks for the offer, not sure I'd be able to fix the broken pins which is a worry. I'll have to source a working one somewhere, maybe the breakers will have that too ( should have asked them, d'oh )
Post #163828 11th Jan 2013 8:17pm
You could bye-pass the broken pin by going into the unit, soldering a thin wire onto the relevant socket connection, bringing the cable out of the unit casing and connecting directly onto the relevant plug cable.
Did it on a Lear DSP unit and it worked perfectly.
Post #163851 11th Jan 2013 9:21pm
mrd1990
Job done!
Shocked
Post #172307 14th Feb 2013 5:44pm
blimey looks like one of those BT sub station boxes...good job Thumbs Up ... - .- -.
Post #172308 14th Feb 2013 5:46pm
klf400
did you solder the wires together ? 1990 3.5 v8 defender
2000 4.6 v8 30th anniversary prins lpg
2004 4.4 v8 vogue prins lpg
2011 4.4 TDV8 Vogue
faultmate extreme
rsw allcoms
Autel 906BT
Gap iiD tool
Post #172361 14th Feb 2013 8:45pm
mrd1990
I used connection blocks for the thick wires and for the small speaker wires I used my old tried and tested method of stripping back 5 cm of skin, then twisting the wires until they stuck together solidly, electrical insulation tape to seal and protect each connection. The entire cable will be put in plastic piping so it's future proof.
I was going to use an sealed ammunition box to house the replacement amp but the amp is an inch too big to fit Rolling Eyes
Post #172363 14th Feb 2013 8:55pm
ccfj1
^^ No offence mate, twist and tape is in no way good enough for the power that will be going through them wires.
You really need to solder and heat shrink, yes it takes a little longer but will be a proper job that you can rely on, first bump you hit and you could get a short that will blow up the new amp and or set fire to the car.
Post #172443 15th Feb 2013 10:55am
