Home > Maintenance & Mods (L322) > 05 v8 coolant
STEV8
England 2005 Range Rover Autobiography 4.4 V8 Java Black
05 v8 coolant
my coolant needs a top up so ordered the basf one from the handbook.mine currently looks yellow-does this sound right?heard of blue/red/orange one`s before but not yellow.can anyone put my mind at rest before i top up Thumbs Up 05`V8 AUTOBIOGRAPHY
Post #163397 10th Jan 2013 5:37pm
mattstevenson2005
United Kingdom 2003 Range Rover Autobiography 4.4 V8 Java Black
hi
your coolant should be red/pink colour use the GM coolant its the same as land rovers but much cheeper i got mine from a independent range rover garage cost me £20 for 10 litres, empty your system using the radiator tap and take a bottom pipe off drain then refill with the correct fluid just make sure to bleed the system correctly before you drive the vehicle.
Matt
Post #164126 12th Jan 2013 10:49pm
