Home > Technical (L322) > IIDTool from gap diagnostics ***Q & A ***
Page 20 of 49 <123 ... 192021 ... 474849>
The Brains Trust
Australia 2003 Range Rover HSE Td6 Adriatic Blue
Thanks for that Steve. I thout I tried it with the ignition turned on at one stage, but I'll go and try it now it has (and I have) cooled down a bit. Laughing
Cheers - Gav.
Post #163944 12th Jan 2013 11:38am
The Brains Trust
Well, 1 from 2...
Service reset procedure worked - thanks for that, but I still can't see a lot of the ECU's for some reason, and when I try to do a RESET ALL, it counts through to CLEARING 9, then comes up with UPDATE FAILED, then says CLEARING 10, then exits the tool. Tried it with the key in every position, including with the car running, so I'm a bit stumped. It used to go through to about 25 or something like that.
Cheers - Gav.
Post #163946 12th Jan 2013 11:54am
try a software update from the gap site, you might have the correct version already but it might be corrupt..and check the pins in the obd port and IIDTool are not bent.. ... - .- -.
Post #163947 12th Jan 2013 11:57am
The Brains Trust
Thanks Stan - will do. Thumbs Up
Post #163948 12th Jan 2013 12:01pm
mjdronfield
Could be a daft question, but how will we know when GAP have upgraded software available for the IID Tool ?
Will owners get an email ?
or is it a matter of going on their web site from time to time ?
Cheers 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #169627 2nd Feb 2013 8:56pm
i'm sure that Steve will come on here and let us know.... ... - .- -.
Post #169629 2nd Feb 2013 9:01pm
cliffy
2004 Range Rover Vogue 4.4 V8 Zambezi Silver
What have people done re lowering there FFRR using the tool??
Has anyone played with it on suspension settings??
Post #170447 6th Feb 2013 10:40am
i played with mine and eventually settled for -10mm all round... ... - .- -.
Post #170451 6th Feb 2013 11:15am
cliffy
Cheers Stan
Ill wait till next month went I put my 20's back on and give it a go
Thanks
Neil
Post #170485 6th Feb 2013 2:23pm
cliffy
Luv this gadget just found the alarm chip option for locking and unlocking its wicked
Post #170521 6th Feb 2013 5:34pm
best tool out there me thinks... Thumbs Up ... - .- -.
Post #170524 6th Feb 2013 5:46pm
comports
United Kingdom 2016 Range Rover Autobiography SDV8 Mariana Black
Reset
Hi Steve
You mentioned in an early post on here that some ecu's may not be changed if an RAC tool had been used in the past and changed default settings. I believe you also mentioned that these could be reset via the IID tool. I think I may be suffering from this as lots of things won't actually set.
Eg park heating or aux heating. IID does change then to enabled but hey don't show up. Same with follow me home lights.
Is there a way to reset the ecu's back to standard so I can start afresh?
Thx a million in advance! Ash
2022 SDV8 AB
2016 TDV8 VSE
2011 TDV8 VSE
2006 V8 Vogue
2002 2.5 Vogue
Post #170579 6th Feb 2013 9:49pm
mjdronfield
May not help, but to get the park heating enabled, you also have to do a reset on the instrument cluster after the 2 iid tool settings.
Disconnect the battery and reconnet or go into the hidden menu and choose the test for "reset".
Fine after that. Aux Heating/Vent in menu........
I covered it in another thread I think.........
EDIT - sorry - its on page 19 of this thread !! Embarassed 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #170580 6th Feb 2013 9:55pm
comports
You Genius MJ (and probably others too)
This is what I love so much about this forum. People finding cure fix's and sharing them.... Me being me, I Just popped out to the car, did the cluster reset following your procedure to code 21 and hey presto..!! I now have Aux Heating/Vent on the menu... set for tomorrow morning to test it all out.
Thank you so much guys.!
I is one happy camper. (until I get a flat battery because the FBH is now working..!) Shocked
ps - just need to fix the follow me home lights and i'm done for now. Ash
2022 SDV8 AB
2016 TDV8 VSE
2011 TDV8 VSE
2006 V8 Vogue
2002 2.5 Vogue
Post #170585 6th Feb 2013 10:15pm
comports
Oh and did I mention just how much I love the IID tool. Great work Steve..!! Ash
2022 SDV8 AB
2016 TDV8 VSE
2011 TDV8 VSE
2006 V8 Vogue
2002 2.5 Vogue
Post #170586 6th Feb 2013 10:16pm
