Home > Technical (L322) > engine wont start
Page 1 of 4 1234>
BOBCUSSEN
France 2004 Range Rover Vogue Td6 Java Black
engine wont start
HELP FOLKS Rolling with laughter Rolling with laughter Rolling with laughter Rolling with laughter Rolling with laughter about 2 hour ago i went out to the RR and started it up . it started first turn of the key as it always does. i let it run for several minutes as it hasent been running for the week. anyway turned it off and have just gone out again to go out, got in tried to start it but it just turns over continuous with wanting to fire up Bow down Big Cry Big Cry Big Cry Big Cry Big Cry Big Cry . i have tried it several times but just turns over. it is a new battery so has plenty of go in it, just wont start.
if it is any help, the car is parked in next doors drive on a bit of a slope facing down the slope. the fuel tank gauge shows 143 miles of range and the gauge shows just under quarter. i have parked in this position plenty of times before without a problem,
everything else is working electrical wise Question Question Question any ideas guys as im in panic mode
bob
ps its a td6
Post #164000 12th Jan 2013 4:13pm
taskam
Scotland 2007 Range Rover Vogue SE TDV8 Java Black
Probably the fuel pump. Happened to me when I had a TD6, just went without any warning when I tried to start after a short run. 2007 TDV8 Vogue SE Java Black
Post #164002 12th Jan 2013 4:20pm
BOBCUSSEN
thanks for the reply, seems strange that it started perfectly. so could it just fail like that Question is there any way of checking if its working Question . i guess a silly question but is it the same pump that is used by the FBH and if not where is the pump situated Embarassed Embarassed
bob
Post #164006 12th Jan 2013 4:26pm
could you roll down off the drive so the range is more on a flat....then try to start it again. ... - .- -.
Post #164007 12th Jan 2013 4:28pm
BOBCUSSEN
hi stan, i had thought of that but im concerned i wouldent be eble to stop Whistle Whistle ,on in the neighbours gravel drive and and the drive runs about another 40metres with a big ditch at the bottom. not having any air in the system, i dont know if i would be able to stop it. especially as the hand break is not that great Whistle
bob
Post #164010 12th Jan 2013 4:34pm
could be a problem then and maybe doing that might not help...it does sound like fuel starvation though.. ... - .- -.
Post #164020 12th Jan 2013 4:59pm
BOBCUSSEN
hi stan, well i have managed to roll it down onto level ground, but it still wont start. can you advise how i can test if the fuel pump has failed Question as suggested as a possible problem. i have just had the fbh working so im not out of fuel, and obviously is not the same pump as the one for the engine. is there a picture anywhere showing the pump and its location Question
bob
Post #164023 12th Jan 2013 5:04pm
Have a read at this thread
Post #164026 12th Jan 2013 5:13pm
mjdronfield
Top of fuel tank ;
2 is fuel pump
4 is secondary fueld pump.
Can you hear them buzzing ?
Tap with hammer ? 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #164028 12th Jan 2013 5:17pm
BOBCUSSEN
hi mate, thanks for the picture. is the main pump accessed under the spare wheel?, also i have had a look under the bonnet and just to the right on the engine nearer to the front than the rear is what looks like a pump/filter type of thing, which is sitting in a upright position, along with several tubes, a couple of which are clear. these seem to be full of diesel with no air blocks, but there is also a small plastic sort of bowl which is also connected to the other piece via a tube but that is empty Question is this anything to do with the fuel system is is it something else. perhaps it would be better to post a picture from under the bonnet.
anyway as the car is in access mode, i expect this will stop me from getting at the secondary pump to have a look, do you think Question Question
bob
Post #164033 12th Jan 2013 5:29pm
mjdronfield
Looks like the access panels are more under the rear seat, forward of the spare wheel well............
Is this thread any use for the underbonnet pipes, or are you in a different area ?
http://www.fullfatrr.com/forum/topic12231....uel+filter 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #164050 12th Jan 2013 6:09pm
BOBCUSSEN
hi mate, thanks for the pictures. looking at the fuel filter pics, the little plastic bowl,( just to the bottom left of the main filter ), about the size of a cotton reel Question on your pics looks like it has a little filter in it and has fuel inside it Question ? is that correct, ie is it another filter for the fuel Question
the reason i ask is although the see trough pipes have fuel in , my little plastic thing is actually empty Exclamation Exclamation Exclamation Exclamation , and wonder if that puts anymore light on the issue as to my problem.
bob
Post #164051 12th Jan 2013 6:26pm
mjdronfield
Will check filter in a sec...........though on the other thread, I'm told its the breather for the gearbox............
Bit more info ?
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #164055 12th Jan 2013 6:53pm
It is a breather and nothing to do with fuel
Your problem is the fuel pump under the vehicle not the one in the fuel tank. See my previous post
Post #164057 12th Jan 2013 7:04pm
BOBCUSSEN
wow, that high pressure fuel pump looks expensive Big Cry Big Cry but i guess at this time i dont really know what is the problem. Question what doesent make sense to me is that there is fuel in the clear plastic tubes, and would have thought if the pump had packed up, the pipes would have been empty Question , but perhaps it dont work like that Exclamation Exclamation
can you suggest a process of elimination, like i guess firstly removing the inlet to the filter and crank over to see if fuel is reaching the filter in the first place Question , but if not where should i go from there Censored Censored Censored
Post #164059 12th Jan 2013 7:07pm
Page 1 of 4 1234>
