![]() | Home > Technical (L322) > engine wont start |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7995 ![]() ![]() ![]() |
that sounds like the next plan of attack then.........
BOBCUSSEN Member Since: 25 Nov 2012 Location: DORDOGNE Posts: 296 ![]() ![]() ![]() |
hi 47P2 do you think it is the secondary filter then? if so how could i test it, and is it get atable without being on a ramp
Think its just the other side the sill........
if i do remove the tube to the filter and nothing comes through, how would i know if the problem was the main pump on top of the tank or the secondary one under the car |
Re the removal of tubes, I'd imagine you'd remove the feed to the secondary pump, and see if fuel is pumped when ignition is on. If so, main pump in tank is going.
Looking at this forum for the past two years, your most likely candidate is the secondary fuel pump. Luckily it is the easiest to replace and the cheapest of the pumps. Pity you didn't have any previous warning. I hope you get it sorted soon (and the statistics are in your favour of course). MY 2010 5.0 SC Galway green and sand interior!!
Benfelrr Member Since: 27 May 2012 Location: Wiltshire Posts: 301 ![]() ![]() ![]() |
Really hope this doesnt sound like taking the |
HI GUYS
JAYBOY Member Since: 17 Oct 2012 Location: South Wales Posts: 2204 ![]() ![]() ![]() |
I hope it starts in the morning for you. |
I'm pretty sure the FBH has its own system, if I remember right from a month or so ago when I read about it.
thanks lads, keeping everything thats long enough crossed |
Even if tapping the pump won't help it going, it may still be screwed. I hope it is just the pump as it is probably the easiest apart from no fuel. MY 2010 5.0 SC Galway green and sand interior!!
unbelievable
