![]() | Home > Technical (L322) > engine wont start |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35679 ![]() ![]() |
i gather you're happy then |
BOBCUSSEN Member Since: 25 Nov 2012 Location: DORDOGNE Posts: 296 ![]() ![]() ![]() |
hi stan, ha ha yes i am, but mainly i went into panic mode as im living in the middle of the french countryside; with no dealer for a 50 miles. plus i had just rolled the rangie down the neighbours drive and was now parked right in front of a ditch. ( dutch neighbours, but only holiday home ) fortunately,
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7917 ![]() ![]() ![]() |
We are The FF Collective. Resistance is futile !!
no worries, i will get one ordered straight away. i dont need to use the rangie as i have other means, so will probably just keep it in My drive until its sorted. ( it was only in next doors as i waiting for electric company to trim our trees that are touching their cables )
hi guys, just waiting to receive the secondary fuel pump from Dan, and i am yet undecided as to whether i will attempt to do it myself or put it into the dealers. would it need to be bled manually or is it simply a case on turning the ignition on for a period before starting? also if i do put it into the dealers, how long a job would you expect it to be |
No need to bleed, turn the ignition on for a minute, turn it over and Bob's your Auntie Fanny |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16341 ![]() ![]() ![]() |
Just put the ignition on once fitted and it will self bleed... ![]() |
steptoe Member Since: 23 Jul 2012 Location: london Posts: 382 ![]() ![]() |
What you've had is the warning it's on it's way out. ![]() |
THANKS GUYS for the replies |
hi again lads, i have just received the pump from dan this afternoon, and am now wondering whether to attempt the changeover myself, or get it to the dealers |
Have a read at this thread again Click |
thanks for that. sorry i had forgot you had already posted the details. |
Hey Bob, these type of clips can be gotten from any good automotive parts place that supplies to garages. Find one in your area (not sure if Brezan operates in France already, they do in Holland and Belgium). Make sure you get stainless steel ones !! MY 2010 5.0 SC Galway green and sand interior!!
thanks for that, i will have a look around but if i cant find any, i will ask the local garage. not a dealer but it saves going 70 miles to the next one.
