![]() | Home > Technical (L322) > New key? |
ahebron Member Since: 01 Jan 2012 Location: The other Eastbourne Posts: 341 ![]() ![]() |
What do I need to do to make this work for my 2003 TD6 HSE.
Hello Geotoy.
I believe the only route is a new key from LR. £££ |
Geo2toy Member Since: 04 Nov 2012 Location: Wiltshire Posts: 76 ![]() ![]() ![]() |
No but you have to do both keys within about 30 seconds or so i had to do it a couple of times as i was a bit slow on getting the button sequence of pat. |
I bit the bullet and ordered a key. It arrived i just over a week and came with a complimentary sweetie.
tomthevet Member Since: 14 Jan 2012 Location: Scotland Posts: 283 ![]() ![]() ![]() |
If you buy a blank off ebay and have a good cut key but whose electronics are duff (but with a working transponder) its a relatively easy thing to gently heat the metal part til you can pull it free (it melts the small platic dowel through the metal part), swap them over and araldite into the new holder with transponder swapped across.
