![]() | Home > Technical (L322) > BIG issue: locked out of the car [SOLVED] |
Ibartsimp Member Since: 25 Dec 2012 Location: Bordeaux, France Posts: 197 ![]() ![]() ![]() |
Wow, I think I now have a BIG issue. The battery went down during the night to the point where I can't now open the doors with the remote control. Here comes the BIG issue, the car is locked and the driver's door got a problem yesterday that predvents me from opening it mechanically from the outside.
nope |
mrd1990 Member Since: 01 Jun 2011 Location: N. Wales Posts: 267 ![]() ![]() ![]() |
maybe this: http://www.rangerovers.net/forum/6-range-r...ttery.html |
woodchopper23 Member Since: 20 Jan 2012 Location: cumbria Posts: 259 ![]() ![]() ![]() |
If you remove the belly pan under the engine, the alternator plug is accessable. So surely you could charge the battery through thy plug. You would just need to identify the pin out of the plug to locate 12v and ground. MY2010 TDV8 Vogue Ipanema Sand
You can either connect a spare battery or battery charger to a white tow socket as above, or you can connect a spare battery or battery charger by connecting to the red cable starter connection and an earth point on the car. You need to lie under the car to do this.
Ok, so relieving, thanks a lot, you guys are fast and accurate!
I had an RAC jump start our Motorhome by Negative to chassis & Positive direct to the Starter Motor. Not sure if this can be done on a RR. |
Managed to get in the car with the blinker method |
You will need to charge the battery from now until tomorrow morning to get a reasonable charge into the battery, particularly as current is draining away at the same time. Be patient. |
Those defenders really are under-powered |
yes the doors were unlocked by the remote key. |
SKOT Member Since: 24 Oct 2012 Location: Milton Keynes Posts: 792 ![]() ![]() ![]() |
My driver's door lock wasn't working with the key in the barrel and I was worried about the very same thing; battery going flat and how I would get in. I'm glad you solved it.
maybe security reasons ?
Security? Nah - Cost cutting. It's much much cheaper to put a blanking plate than it is a lock..... |
