![]() | Home > Technical (L322) > Where am I ? |
JohnnyDangerous Member Since: 16 Dec 2012 Location: East Sussex Posts: 833 ![]() ![]() ![]() |
Bermuda Triangle !!! did you see any old fighter planes?? One day your life will flash before your eyes......................................make sure yours is worth watching!
Johnte Member Since: 23 Aug 2010 Location: North Yorkshire Posts: 745 ![]() ![]() |
They say a strange mist comes down in the triangle !!!!! Hopefully you are ok, if you wake up with a sore arse you may well have been abducted |
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6830 ![]() ![]() ![]() |
New road, out of date disc? Got - 2017 SDV8 Autobiography in Loire Blue
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35813 ![]() ![]() |
loss of gps signal.. ... - .- -.
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3982 ![]() ![]() ![]() |
You were in the middle of a field.... |
Was on A19, not a new section, but a part that's always been the same..
cold and wet outside, warm inside, makes ideal conditions for condensation so its possible that some moisture might have got in the antenna connections or into the modules...once the weather gets dryer you'll probably find all is well again... ... - .- -.
Was hoping this might be the case |
So when it's cold and wet, make sure you've got a TomTom handy! |
Very likely water/moisture ingress into the GPS antenna. Common issue when Sat Nav loses its way. GPS Icon top left of screen will have a red line through it.... |
jim2RRs Member Since: 07 Feb 2012 Location: Genesee, Colorado Posts: 147 ![]() ![]() ![]() |
East of the Sun, West of the Moon?
XXXAngelXXX Member Since: 25 Mar 2007 Location: Stuttgart Posts: 4995 ![]() ![]() ![]() |
Twilight zone |
